Posted February 12, 20178 yr Wintoolkit v1.5.4.8 keeps on crashing when I try to use the AIO integrater and apply changes when it finishes un-mounting an image it crashes screenshots and settings will be attached I'am also using one addon: the Directx_june2010 x86.WA Can someone verify if this is a bug or is it some settings conflict Thanks for your help in advance BTW i disabled all Antiviruses and anti malware suites Settings.txt Session save.ini Edited February 12, 20178 yr by ZERO_XP missing objects
