adminxp Posted March 9, 2017 Posted March 9, 2017 (edited) i select drivers to integrate (3056 drivers) and start the proccess. in the end i got final screen where is no any drivers integrated. version used 1.5.4.10. DISM from win 10 is installed p.s. last version which works correctly for me is Win.Toolkit.1.5.3.03 Edited March 9, 2017 by adminxp Quote
DerBaronTV Posted March 28, 2017 Posted March 28, 2017 same here, choosing my folder with the drivers and the list keeps empty, doesn't find any driver. using 1.5.4.10 - the version before worked as a charm Quote
adminxp Posted April 1, 2017 Author Posted April 1, 2017 i have solved the issue by placing working and temp folder same drive. also WT does not like short paths. DIdnt accept E:\Mount - but E:\MOunt\Mount was ok - and integration went normal Quote
digital john Posted May 4, 2017 Posted May 4, 2017 i have drivers map name win 10 x64, it didn't integrate anything, i hope they fixed on 1.5.4.11 or 12 Quote
Legolash2o Posted October 24, 2017 Posted October 24, 2017 Maybe try the latest build. http://wintoolkit.co.uk/Home/TestBuilds Quote
