Posted April 20, 20177 yr Hi im new to this forum. Maybe i'm just to stupid but for me it does not work to load more than one installation file. When i load one installation file and then another, the entries from the first file disappear. I'm using the version 1.5.4.9. Hopefully some can give me some advice. Thanks!
April 20, 20177 yr Hi and welcome. That's the correct behavior, if you want to edit/merge images, you should use WIM Manager or All In One Disk Creator.
