Posted May 31, 20177 yr hi Please silent installation command in cmd file with the extension wa Example : unlocker.wa
June 8, 20177 yr Author On ۲۰۱۷/۰۵/۳۱ at 7:41 AM, Ali Sahandi said: hi Please silent installation command in cmd file with the extension wa Example : unlocker.wa No one to answer in this forum
June 8, 20177 yr As far as I know .wa files are directly integrated with WinToolkit. .wa files are addons not installers so they are already silently added into the instalation. Are you using them correctly as addons in WinToolkit?
June 9, 20177 yr Author 15 hours ago, ianymaty said: As far as I know .wa files are directly integrated with WinToolkit. .wa files are addons not installers so they are already silently added into the instalation. Are you using them correctly as addons in WinToolkit? hi For some reason I am through the installation SetupComplete
June 9, 20177 yr Then try with original installer http://www.emptyloop.com/unlocker/#download Unlocker1.9.2.exe /S
