2 hours ago, Adilson Enio Pierog said:
I need the Windows 7 ISO Portuguese Brazilian (pt-br) language  but is not listed on selection box.
Please see the print below:
That Portuguese version is from Portugal but I'm from Brazil. What can I do?
Olá. Está disponível para a versão Pro. Ou então vc pode instalar o language pack portugues BR posteriormente.
9 hours ago, Jan Krohn said:
You can also convert the Brazilian Win 7 Pro to a universal Win 7 disc with the ei.cfg removal utility:
http://code.kliu.org/misc/winisoutils/
If you prefer to have direct access to the Brazilian Win 7 Home, please help me find someone who would donate a suitable key to unlock the download, for me to integrate it into the tool.
Thank you, Jan. I've downloaded the PRO iso file and removed the ei.cfg. Now I have all versions avaliable to install.
Problem solved!
