Tech Vip Posted November 15, 2017 Posted November 15, 2017 Hello, i use HEIDOC tool for quite sometime and now in every pc i use its says that i must log on into my Microsoft Account! Where should i log on? I dont see nothing to put my Microsoft Credentials Please Help. Quote
Jan Krohn Posted November 15, 2017 Posted November 15, 2017 The login link is in the top right of the main area. Please give feedback whether this helps. Login should only be requred for downloading Insider Preview and developer images. However, I've received a few messages now that login is randomly required, and doesn't solve the issue of not getting access to the downloads. It looks like MS has changed something on the download page. I've not been able to replicate this error, so any further insights would be helpful to fixing this permanently. Quote
Wilson carvalho Posted November 15, 2017 Posted November 15, 2017 Tambem estou com o mesmo problema. Fiz login na minha conta da microsoft mas mesmo assim não deu certo. Ja tem alguma solução? Quote
Jan Krohn Posted November 15, 2017 Posted November 15, 2017 Can you provide a screenshot? I can't replicate the issue. Quote
Kazcram Posted November 15, 2017 Posted November 15, 2017 1 hour ago, Tech Vip said: Hello, i use HEIDOC tool for quite sometime and now in every pc i use its says that i must log on into my Microsoft Account! Where should i log on? I dont see nothing to put my Microsoft Credentials Please Help. Same problem here - screenshot and debug info ( sorry for pagan language ): Szczegółowe informacje na temat wywoływania debugowania w trybie JIT (just in time) zamiast tego okna dialogowego znajdują się na końcu tego komunikatu. ************** Tekst wyjątku ************** System.NullReferenceException: Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu. w Windows_ISO_Downloader.Form1.Timer1_Tick(Object sender, EventArgs e) w System.Windows.Forms.Timer.OnTick(EventArgs e) w System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m) w System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Zestawy załadowane ************** mscorlib Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2115.0 built by: NET47REL1LAST CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- Windows ISO Downloader Wersja zestawu: 5.2.5.0 Wersja Win32: 5.2.5.0 CodeBase: file:///C:/Users/Kazcram/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- Microsoft.VisualBasic Wersja zestawu: 10.0.0.0 Wersja Win32: 14.7.2046.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System.Windows.Forms Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2110.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2110.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2046.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Configuration Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2046.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Core Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2117.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Xml Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2102.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Runtime.Remoting Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2114.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- mscorlib.resources Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2046.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/mscorlib.resources.dll ---------------------------------------- Microsoft.mshtml Wersja zestawu: 7.0.3300.0 Wersja Win32: 7.0.3300.0 CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll ---------------------------------------- lum_sdk Wersja zestawu: 1.68.308.0 Wersja Win32: 5.2.5.0 CodeBase: file:///C:/Users/Kazcram/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- System.Windows.Forms.resources Wersja zestawu: 4.0.0.0 Wersja Win32: 4.7.2046.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- ************** Debugowanie w trybie JIT ************** Aby włączyć debugowanie w trybie just in time (JIT), plik .config tej aplikacji lub komputera (machine.config) musi mieć wartość jitDebugging ustawioną w sekcji system.windows.forms. Aplikacja musi być również skompilowana z włączonym debugowaniem. Na przykład: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> Gdy debugowanie JIT jest włączone, wszystkie nieobsługiwane wyjątki są wysyłane do debugera JIT zarejestrowanego na komputerze i nie są obsługiwane w tym oknie dialogowym. Quote
Henri Asi Posted November 15, 2017 Posted November 15, 2017 (edited) Same here... It does not matter if I log in or not. Spoiler See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at Windows_ISO_Downloader.Form1.Timer1_Tick(Object sender, EventArgs e) at System.Windows.Forms.Timer.OnTick(EventArgs e) at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.7.2110.0 built by: NET47REL1LAST CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- Windows ISO Downloader Assembly Version: 5.2.5.0 Win32 Version: 5.2.5.0 CodeBase: file:///C:/Users/Henri/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 10.0.0.0 Win32 Version: 14.7.2053.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.7.2110.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.7.2110.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.7.2053.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.7.2053.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.7.2106.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.7.2102.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.7.2053.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 4.0.0.0 Win32 Version: 4.7.2114.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- Microsoft.mshtml Assembly Version: 7.0.3300.0 Win32 Version: 7.0.3300.0 CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll ---------------------------------------- lum_sdk Assembly Version: 1.68.308.0 Win32 Version: 5.2.5.0 CodeBase: file:///C:/Users/Henri/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- lum_sdk_int Assembly Version: 1.68.308.0 Win32 Version: 5.2.5.0 CodeBase: file:///C:/Users/Henri/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- util Assembly Version: 1.68.308.0 Win32 Version: 5.2.5.0 CodeBase: file:///C:/Users/Henri/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.7.2106.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.7.2106.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.7.2106.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.7.2106.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- System.Management Assembly Version: 4.0.0.0 Win32 Version: 4.7.2102.0 built by: NET47REL1LAST CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Newtonsoft.Json Assembly Version: 9.0.0.0 Win32 Version: 5.2.5.0 CodeBase: file:///C:/Users/Henri/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.7.2053.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll ---------------------------------------- PresentationFramework.Aero2 Assembly Version: 4.0.0.0 Win32 Version: 4.7.2053.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll ---------------------------------------- System.Deployment Assembly Version: 4.0.0.0 Win32 Version: 4.7.2053.0 built by: NET47REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll ---------------------------------------- AsyncBridge.Net35 Assembly Version: 0.0.0.0 Win32 Version: 5.2.5.0 CodeBase: file:///C:/Users/Henri/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- System.Threading Assembly Version: 1.0.2856.102 Win32 Version: 5.2.5.0 CodeBase: file:///C:/Users/Henri/Downloads/Windows%20ISO%20Downloader.exe ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.7.2053.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. Edited November 15, 2017 by Henri Asi Quote
Samuel de Araújo Posted November 15, 2017 Posted November 15, 2017 here also even login does not let you download. I'll send screenshot. Quote
Samuel de Araújo Posted November 15, 2017 Posted November 15, 2017 if anyone has an idea of what to do thank you if you can teach. Quote
ROBOTIX Posted November 15, 2017 Posted November 15, 2017 (edited) Same problem here. In Spanish It's asking to login to a MIcrosoft Account and try back again Edited November 15, 2017 by ROBOTIX Quote
Tech Vip Posted November 15, 2017 Author Posted November 15, 2017 When i put language in Portuguese(pt-PT) the tool ask for us to delete some lines in the HOSTS file from windows! If i put the tool in English its says that needs to login to Microsoft Account! I login but doesn't let me download the ISO's gives me the same error that everybody is having Quote
Jan Krohn Posted November 15, 2017 Posted November 15, 2017 I can replicate the bug using pt-PT language settings. I'll work on the patch tomorrow. For now, the workaround is using en-US settings. This will (hopefully) generate download links as usual. Quote
Tech Vip Posted November 15, 2017 Author Posted November 15, 2017 34 minutes ago, Jan Krohn said: I can replicate the bug using pt-PT language settings. I'll work on the patch tomorrow. For now, the workaround is using en-US settings. This will (hopefully) generate download links as usual. OK Jan, Thanks for the hard work Quote
Samuel de Araújo Posted November 15, 2017 Posted November 15, 2017 does anyone know how to solve the problem of eliminating host lines I think if you do this here solve Quote
Alena Vi Posted November 15, 2017 Posted November 15, 2017 33 minutes ago, Samuel de Araújo said: does anyone know how to solve the problem of eliminating host lines I think if you do this here solve en us works! Quote
Christian Axelsson Posted November 16, 2017 Posted November 16, 2017 (edited) I have the same problem but I can't even change language so.. I've tried different computers, different windows versions.. I really need that iso file.. edit Problem solved now! Thank you so much! Gonna sleep well now and happily format c: tomorrow Edited November 16, 2017 by Christian Axelsson Quote
Jan Krohn Posted November 16, 2017 Posted November 16, 2017 The localized Windows 10 download pages on Microsoft.com also give an error. So this is a Microsoft issue. For the time being, I've just uploaded version 5.26 which displays any content integrated from Microsoft.com in en-US. Once MS has fixed their issue, I'll revert back to localized content. Quote
Gercan311 Posted November 16, 2017 Posted November 16, 2017 Buen dia para todos, me aparecia el mismo error incluso poniendo mi cuenta de microsoft, sin embargo configure la herramienta y la puse en ingles, al seleccionar el sistema operativo, me salio la opcion normal de elegir el idioma de descarga, el resto de proceso fue el normal. Quote
Tech Vip Posted November 16, 2017 Author Posted November 16, 2017 23 hours ago, Samuel de Araújo said: does anyone know how to solve the problem of eliminating host lines I think if you do this here solve Usa em Ingles US isso do HOSTS acho que é ma tradução do programa. Quote
Tech Vip Posted November 16, 2017 Author Posted November 16, 2017 23 hours ago, Samuel de Araújo said: does anyone know how to solve the problem of eliminating host lines I think if you do this here solve Esquece em PT ja funciona Quote
Eid Posted November 20, 2017 Posted November 20, 2017 i had the same problem but i solved this by going to control panel / region/ then change format and locations to USA. my set up before was Saudi Arabia . now i am using windows 8.1 enterprise evaluations . in windows 7 go to control panel / language and region / then change format and locations to USA. note : i set up back to Saudi Arabia but the problem back again and then set up to USA and the download appears to be downloaded ok i downloaded some of windows and office and that was perfect . Quote
Ozan Posted November 20, 2017 Posted November 20, 2017 Has anyone fixed it? It is possible to download now, without changing the region! Quote
DiJane Posted December 22, 2017 Posted December 22, 2017 Hi. I#m using version 5.28 and could successfully download some required iso-files as of December 9th. Today I realized that one iso file is broken so I would like try to download this file again but it seems that the service is down?! I'd like to do download Win 7 Ultimate German x64 so I tried first to download the German version but changing the language to English, UK also does not work. I would be very happy if you could help! Kind regards, DiJane. Quote
Thiersee Posted December 22, 2017 Posted December 22, 2017 @DiJane Have a look here: https://www.wincert.net/forum/index.php?/topic/13728-ms-downloads-api-current-issues/&tab=comments#comment-122467 Regards Quote
