PotPlayer 240905 (1.7.22319) Estable x86x64 [Multilingual][Desatendido]
Changes in Daum PotPlayer 231102 (1.7.22031):
  • Added the ability to display multiple lines in the subtitle explorer
  • NOTCHLC video codec playback function added
  • Modified to apply HDR color correction when capturing video if possible
  • Fixed an issue where the DTS pass-through function did not work on certain systems
  • Fixed an issue where embedded subtitles were displayed overlapping when playing files without interruption.
  • Fixed an issue where playback completion did not occur when using the delete related file function upon completion of playback.
  • Fixed a problem that freezing when playing HEVC with DXVA on old Intel GPUs
  • Fixed an issue where certain MKV videos could not be played after searching for them.
  • geodasoft changed the title to PotPlayer 231110(1.7.22037) Estable x86x64 [Multilingual][Desatendido]
  • Replies 55
  • Views 31.9k
  • 1.7.20538 2019/09/19 * Changed default HEVC decoder to Built-in FFmpeg HEVC H/W Decoder + Added support for YTT subtitles + Added support for external chapters files (.chapters.xml) - Fixed
  • great app! thx!
  • geodasoft changed the title to PotPlayer 240309 (1.7.22124) Estable x86x64 [Multilingual][Desatendido]
Changes in Daum PotPlayer 240309 (1.7.22124):
  • Added NVIDIA RTX Video HDR function
  • Added ability to move files to playlist
  • Fixed an issue where damaged WAV files could not be played
  • Fixed an issue where the screen was broken when playing certain MPEG4 codecs
  • Fixed an issue where the screen did not appear when playing certain WMV videos
  • Fixed an issue where certain SRT protocols did not work
  • Fixed an issue where an error occurred when playing certain TS files
  • Fixed an issue where an error occurred in certain situations when playing some VP8/9 codecs.
  • geodasoft changed the title to PotPlayer 2040514 (1.7.22230) Estable x86x64 [Multilingual][Desatendido]
Changes in Daum PotPlayer 240509 (1.7.22224):
  • Added Dolby Vision HDR playback function
  • Fixed an issue where the screen did not appear when playing some MP4 files
  • Improved built-in D3D9 renderer stability
  • Fixed an issue where files in compressed files could not be played properly
  • Fixed an issue where the screen was broken after navigation when playing certain MPEG 2 with DXVA
  • geodasoft changed the title to PotPlayer 2040618 (1.7.22259) Estable x86x64 [Multilingual][Desatendido]
Changes in Daum PotPlayer 2040618 (1.7.22259):
  • Added the ability to set the font for OSD playback information
  • Added the ability to name albums in environment management automatic conditions
  • Added the ability to go to the previous/next section in the section repeat list
  • Added ability to not wait for vertical sync
  • Added system media transport control function
  • Modified the window border skin to be prettier.
  • Modified the subtitle format to be displayed in the name of the built-in subtitles.
  • Fixed an issue where frame steps did not work properly in the built-in video renderer.
  • geodasoft changed the title to PotPlayer 240905 (1.7.22319) Estable x86x64 [Multilingual][Desatendido]
Changes in Daum PotPlayer 24.8.27.0:
  • Added WEBP to video capture
  • Added ability to set delay time to seconds or less in image source filter
  • Added auto-run feature when system starts
  • Fixed an issue where the size settings of the shortcut icon were not reflected.
  • Fixed an issue where the Do not add duplicate files setting was reset in certain situations.
  • Fixed an issue where the video was recognized as interlaced when playing with a specific codec.
  • Fixed an error issue when decoding with libVPX 8/9
  • Fixed an issue where navigation occurred abnormally when playing MP4 streaming.
  • Fixed an issue where browsing certain FLV files was slow
  • Improved subtitle display speed
