Posted April 23, 20186 yr I am having trouble integrating the KB3035126, KB3078601, KB3110329 and KB2834140 updates into my copy of Windows 7. I have tried removing them from the list of integrated updates via DISM and put them in SVCPACK (or whatever it's called in WinToolkit), but they persist in requesting to be downloaded by Windows Update. I need some help, or at least some ideas on how to deal with it (aside from letting the user download them). Thanks in advance! Edited April 24, 20186 yr by dougiefresh2
April 24, 20186 yr Author I've solved my issue. Started over and integrated everything BUT those updates, and placed those updates in the Silent Installs list. Booted up my VM with my homebrew image, and YES, no updates!!! UPDATE: Tried again, same updates show up.... So sad... UPDATE2: Turns out Windows Update needed to check for updates after install. Once the check completed, only 2 updates remained: kb2985461 and the Windows Malicious Software Removal Tool.... Very happy! Hope this information helps someone! Edited April 24, 20186 yr by dougiefresh2
