ClayStation Posted May 4, 2018 Posted May 4, 2018 Application: WinToolkitv2.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: exception code c06d007e, exception address 000007FEFD55AA7D Faulting application name: WinToolkitv2.exe, version: 2.0.0.0, time stamp: 0x58c03949 Faulting module name: KERNELBASE.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdfe0 Exception code: 0xc06d007e Fault offset: 0x000000000000aa7d Faulting process id: 0x119c Faulting application start time: 0x01d3e349740fe59a Faulting application path: C:\Program Files (x86)\WinToolkit\WinToolkitv2.exe Faulting module path: C:\Windows\system32\KERNELBASE.dll Report Id: b1d900fe-4f3c-11e8-92b5-344b50b7ef7e I don't really know what any of that means, but it failed, and that is what it had to say about that. Quote
shhnedo Posted May 6, 2018 Posted May 6, 2018 (edited) On 5/4/2018 at 4:52 AM, ClayStation said: Faulting module name: KERNELBASE.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdfe0 You're using a pre-SP1 windows 7? Actually, scratch that, it started a chain of ram consuming error reports on my 7 pro x64 sp1. @Legolash2oError_18-05-07_003030.zip This is the first one. Every other error report zip that followed just had more screenshots inside. Edited May 6, 2018 by shhnedo Quote
