Just a small question:
to work on an Windows 10 ISO do I need DISM/AIK version 10 for WinToolkit?
I'm working on a Win7 Pro x64 system.
How can I select in WinToolkit-Options which version to use? Simply add?
Thanks in advance.
  • 11 months later...
On 5/30/2018 at 10:47 PM, shhnedo said:
Uninstall your 8.1 kit and download the latest one from MS.
https://go.microsoft.com/fwlink/?linkid=873065
Then add the path to the new dism.exe in wintoolkit. That should do it.
Hey Shhnedo,
Vasudev here. Do you know why I get No SP1 detected when I use Simplix pack to update win 7 Sp1 boot.wim files index=*?
Another question: Won't Win 10 Dism exe conflict with W7's? Win 10 Dism is more powerful with lot of options..
Because the updatepack works ONLY on the install.wim. boot.wim manipulation was never intended or implemented.
No conflicts.
And anyway, servicing windows 8.1/10 isn't fully supported under windows 7. Conversely, windows 7/8.1/10 images can be serviced under windows 10. Simply having and using the adk from a newer OS doesn't provide full support for servicing newer OS images relative to the host OS.
No conflicts.
Thank you.
Edited by vmk
Incorrect quotes
