  • Replies 74
  • Views 37.7k
1.7.1.3360 (this one) is the final build...
hey rick, if its not too much trouble could you take a look at my utorrent addon?
http://www.ryanvm.net/forum/viewtopic.php?t=5043
just a simple switchless installer, but if you know how to take apart and repack addons, you can add your own customized utorrent settings to it :thumb_yello:
Edited by runningfool
You can use Reshacher...
EDIT: I just found out Reshacher wont work but you can do it by having a tray.ico in %AppData%\uTorrent
I will update the addon soon just let me try to find out how to change the .torrent file
Allright, thanks :D
BTW; there are many programs that reshacker doesn't work with, isn't there another prog ? :)
hehe! i cant believe it, another update just after the release of version 1.7.3
version 1.7.5 will be out in 2 days!
hehehe!
