If you can upgrade to IE9, that would probably help.
If that's also not possible, please share which file you need, so I (or someone else) can generate the link.
I'm still working on a fix for display issues on older IE versions.
Hello
unfortunately the Alternative 100% online (fonctionne avec tous les navigateurs et les OS): does not work for download with my params
Edited by GdG
PS. I dont know if it will help, but I could not update W7 with following Update
I then followed a lot of links to correct this problem with no success
Edited by GdG
I got it. Great.
IE 8 installed. Is it normal ?
For information :    IE went with German text (not important for me since I dont use IE)
Edited by GdG
IE8 is delivered with Windows 7, if you do not integrate an higher version.
BTW, your IE8 is in French, but if you select a german URL (/de-ch/) you get the site in German 😉; the UI is still in French.
Edited by Thiersee
Sorry, not familiar with IE since I dont use it.
Have installed some batches of updates.
Some failed.continue until no more
Shall I try to find solutions ?
Edited by GdG
