Posted September 5, 20186 yr Hi, I just want to ask are Office_Pro_2007_English_x32_FPP.exe and X16-69453.exe the same, if so can anyone please provide the SHA-1 hash for the file. Regards, SnowBall Edited October 8, 20186 yr by SnowBall
September 5, 20186 yr That's a tricky question. Both files are the same product for sure. Whether they're the same files, I don't know. There are two records in the hash database. One for the United States, and one for worldwide. https://www.heidoc.net/php/myvsdump_details.php?id=P46F12053Ax86Len https://www.heidoc.net/php/myvsdump_details.php?id=P46F41713Ax86Len If you have the choice, get the one for worldwide, not the US. It contains one additional component which MS had to remove from the US version after a legal dispute. Since both files you quoted were also available to the US, I suspect they're both lacking the custom XML tagging component.
September 7, 20186 yr Author Thanks for the reply, but the links provided were information of Office Professional 2007 - CD (ISO) files, not the Windows Executable files from Microsoft Software Download page and I bet that they are from MSDN. I know this is very tricky question as Office 2007 has reached for its end of support, but anyway I want to say thanks. Regards SnowBall
