Posted September 28, 20186 yr Hello, Thank you for this program. While using it I accepted the running of your extra software in my computer. Later I found a folder, some subfolders, executable and session id in my computer, Luminati stuff. How can I securely remove it? My computer seems to be struggling a lot more now... Not sure when does it stop working also, but I want to delete it totally. Thank you for your time Regards
September 28, 20186 yr Hi, you can simply delete those files and folders. Those files and folders were created by Luminati SDK (lum_sdk.dll) embedded in the ISO Downloader as you chose to donate idle resources. They won't harm your computer and you can delete them without any worries. Regards, SnowBall Edited September 28, 20186 yr by SnowBall
September 28, 20186 yr Correct answer. The next version will remove the file and the folder automatically.
October 3, 20186 yr Author Hello, other than the "Luminati" folder and "lum_sdk_session_id" file in the there are in the same folder where I have your program, is there anything else I should delete? A registry for example? Best regards
October 3, 20186 yr Hi Ric_, there is no registry keys or anything else you need to delete unless you chose to remember settings. Regards, SnowBall Edited October 18, 20186 yr by SnowBall
October 3, 20186 yr The tool doesn't write anything to the registry. Unless you choose to save your settings. In that case, it writes the settings to the .NET settings storage under the application "Windows ISO Downloader". I don't know where in the registry exactly that is. To remove it, untick the box "Remember Settings". No need to go through regedit.
