alacran Posted October 16, 2018 Posted October 16, 2018 (edited) It is my pleasure to share with all of you this Great Tool made with AutoIt: wimlib-clc v181010 first multilang version. Since long time ago Retokener (the author), a very good friend of mine, has been working hard on this project and made several builds since August 2014, this great tool is a Command Line Compiler or in other words a GUI for the fantastic tool of Eric Biggers wimlib-imagex, To use this GUI you need to extract it to a folder (I suggest use wimlib-clc as folder name), preferable to the root of a drive (C:\, D:\, etc.) and download wimlib-imagex x86 or x64 as required (I recommend download v1.13 Beta 5) , links to wimlib-imagex project and download page available on the program Menu under Info, just dowload your required version and make a subfolder x86 or x64 (or both if you want) and put into it libwim-15.dll and wimlib-imagex.exe files respectively, the program will find and use the correct set of files the first time you run it. If you ran before a previous version located on other place, the program could be still pointing to previous location, then on this case on Menu open File >>> Select Program File, and select it on its actual location. For more info on wimlib-clc use you may reed Readme file. Quote File Name: Wimlib-clc File Submitter: ReTokener File Submitted: 15 Oct 2018 File Category: Tools Some may ask, what is wimlib-imagex? To put it in a very general way, wimlib-imagex is an archiver. just to name a few features of wimlib-imagex: wimlib-imagex - is able to backup and restore the entire system partition. - achieves the highest compression rates among its competitors. - Can edit the WIM and ESD archives used by microsoft. The ability to create incremental / differential backups qualifies it as a universal archiving program. It does, however, require the input of the commands via the keyboard. To make the versatility of this tool available to as many users as possible there is now a multilingual graphical user interface for wimlib-imagex. The interface takes over the formulation of the command lines. Wimlib-clc - the command-line-compiler (a development of wimlib_clc) now is the laborious and meticulous typing in of the command lines past. By using the mouse, (almost) all possibilities of wimlib-imagex can be exploited. the use of a tool in your own language should simplify the handling and help to avoid mistakes. therefore, by loading a language file, the surface of Wimlib-clc can now be personalized. Buttons and explanations are displayed in the local language. There are already language files in the following languages: - english (standard) - Spanish - German Everyone is invited to translate the language file for his compatriots and thus make wimlib-imagex accessible for a new language room. just because wimlib-imagex has very special abilities, it is suitable to take on a wide range of tasks. I hope that you succeed with Wimlib-clc to successfully realize all desired projects. Download Wimlib-clc - Password: clc P.S. the enclosed file clc_readme _*-*.txt contains instructions for the use of Wimlib-clc in the respective national language. Many Thanks to Eric Biggers (synchronicity) for the development of wimlib-imagex. to the operators of Reboot.pro for the provision of this platform. especially to alacran for his help with the realization of Wimlib-clc. Regards T. Source: http://reboot.pro/topic/21861-wimlib-clc/#entry207901 Download link: http://reboot.pro/files/file/588-wimlib-clc/ Thread on wimlib forum: https://wimlib.net/forums/viewtopic.php?f=1&t=369 Alternative Mediafire Download link: https://www.mediafire.com/folder/a39a3kebewmlu/Wimlib-clc Password (just in case any stupid AV complains during dowload): clc Author deserves all credit, I only have collaborated with him as Beta tester, Spanish translator, and giving some suggestions. Now for the first time this program is multilingual: English, German and Spanish available for now, translators to other languages are wellcome, into download you can find clc_readme_en-US.txt and clc_en-US.ini, you can use both as a template to translate to you desired language, savig it as clc_readme_xx-XX.txt and clc_xx-XX.ini changing xx-XX for the codes of your translated language, you may use this page as a guide https://ss64.com/locale.html use codes under column "Short string". New translations can be uploaded here: https://www.mediafire.com/filedrop/filedrop_hosted.php?drop=7068e57385e9c4c85920e2c63e18d02c726253cf0c40ee55 Best Regards alacran Edited October 17, 2018 by alacran More info Quote
alacran Posted October 17, 2018 Author Posted October 17, 2018 New version 181017 with very minor changes is available. What's New in Version 181017 = Added: Link to repository. Starting from version 181017 all translations (*.ini and Readme.txt files) are now available on separate folders on: https://www.mediafire.com/folder/a39a3kebewmlu/Wimlib-clc You may download your prefered language files, and just put them on wimlib-clc folder and rename them by deleting from the original name _DATE (as an example clc_es-ES_181017.ini renamed to clc_es-ES.ini), to let the program find them easier (or automatically if you prefer). Quote
