IMAGICON
VERSION 2.4
Imagicon is a free graphics utility designed to convert
multiple image files from BMP, JPG or PNG image
formats into any of the following image formats (24-bit):
Windows or OS/2 Bitmap (BMP)
Independent JPEG Group (JPG)
Portable Network Graphics (PNG)
Windows Icon (ICO)
Options are available to transform images and enable
alpha transparency of icons. The interface window
of Imagicon can be personalized with custom designs.
Screenshot of Imagicon
The user can select to save icons with the following
dimensions in pixels: 16 x 16, 32 x 32, 48 x 48, 64 x 64
and 128 x 128. Imagicon also features the ability to
drag 'n' drop multiple images for faster processing.
Full instructions are included with the software,
explaining each of the possible settings
and the function that they perform.
Minimum System Requirements:
Windows 98/2000/ME/NT/XP/Vista - Pentium 200Mhz CPU
64MB RAM - DirectX 3.0 - 2MB Hard Disk Space
SoundBlaster Compatible Soundcard
Homepage & Download :thumbsdown_anim:
