Hey rick I can't get the nero gadget to work so I tried to uninstall from the control panel but I get a message" error Could not locate INF file DiscCopy inf I would like to get a clean uninstall any ideas? When I try to run nero gadget I get file corrupted please reinstall nero. Thanks I am using you installer and up and running windows sidebar having a lot of fun with it. Seguns
Thats fine I can move the post...
The Uninstall only works if you put the DiscCopy.inf file in %WinDir%\inf (its a hidden folder)
Now try the uninstall
And plese re-download the Nero DiscCopy, I silently updated it
EDIT: What version of Nero are you using and is it Lite or Micro
I am using Nero 7 premium. Uninstall now works placed the file in windows\inf.
Edited by seguns
