Gorki Posted July 22, 2007 Posted July 22, 2007 Ok I'm having some strange problems in taskbar display but ONLY while browsing different drives so when using any other program like paint,mozila, notepad,etc taskbar display full name of application. It's same thing no matter if window is acitve or not.Please look at the picture bellow ...I'm using also visual task tip application. I'm browsing E drive and I get letter L in taskbar? same thing wit some other folder like. Even my computer is displayed with letter M sometimes? :confused02: And these are the tweaks I used with nlite on my winXP source CD:Boot and Shutdown-Numlock-OnDesktop-Internet Explorer icon-HideDesktop-My Computer icon-ShowDesktop-My Documents icon-ShowDesktop-My Network Places icon-HideDesktop-Recycle Bin icon-ShowExplorer-Change Windows Explorer folder view-IconsExplorer-Disable Accessibility keyboard shortcutsExplorer-Disable Prefix: Shortcut toExplorer-Klasični Control PanelPerformance-Disable Optimize harddisk when idlePerformance-Enable USB Idle Endpoint supportPrivacy-Ukloni Alexa SpywareStart Menu-Disable popup on first bootStart Menu-Reduce popup delayTaskbar-Disable Language-Bar Quote
Gorki Posted July 23, 2007 Author Posted July 23, 2007 Gorki's log supplemental: Well I manage to locate the problem, apparently Spyware Terminator installs his crawler toolbar to FF and possibly changes other system entries,I assume ones regarding win explorer shell also, due that I had that ishue,but other than that I did not encounter any other problems.:lock: Quote
