Posted May 11, 20195 yr This error with the Windows PE comes and goes, and I have no clue what is causing it. ALL versions of PE fail, even though they worked before, and there ARE NO DRIVERS MISSING, there is no way around the error. And none of the drives show. It fails on both the vm, and the physical machine, even though I used wintoolkit to integrate the drivers for my machine, and it worked before. This is driving me nuts! Does anyone know what is going on here?
May 22, 20195 yr On 5/11/2019 at 9:57 AM, ClayStation said: This error with the Windows PE comes and goes, and I have no clue what is causing it. ALL versions of PE fail, even though they worked before, and there ARE NO DRIVERS MISSING, there is no way around the error. And none of the drives show. It fails on both the vm, and the physical machine, even though I used wintoolkit to integrate the drivers for my machine, and it worked before. This is driving me nuts! Does anyone know what is going on here? Mount Windows Setup of boot.wim index =2 and sort by latest date in sources folder and copy it over to your source ISO folder and re-create ISO as mentioned here. I wasted nearly 70hrs to figure it out. https://support.microsoft.com/en-in/help/4041170/windows-installation-cannot-find-driver-boot-wim
