Posted July 25, 200717 yr Test the Secunia PSI (BETA) Technology Preview, an upcoming addition to the Secunia Software Inspector series, based on the proven Secunia File Signatures Technology.The Secunia PSI detects installed software and categorises your software as either Insecure, End-of-Life, or Up-To-Date. Effectively enabling you to focus your attention on software installations where more secure versions are available from the vendors.Needless to say, we are very excited about this new free service for the Secunia security community. We appreciate all feedback, thoughts, and ideas that you wish to share with us.Highlights of The Secunia PSI: The Secunia PSI will be available free of chargeCalculates your unique Secunia System ScoreAutomatically scans your computerEnables you to update Insecure/End-of-Life softwareProvides Direct Download Links to security updates & patchesDetects and advises on more than 4,200 applicationsDirect correlation between thousands of Secunia Advisories and your specific system and softwareSecure SSL encrypted connection to SecuniaNOTE: The free Secunia PSI is available for Private/Home Users ONLYSystem RequirementsThe current list of requirements that must be met for the Secunia PSI to function correctly are the following:Supported Operating Systems:* Microsoft Windows XP - Service Pack 2* Microsoft Windows 2003* Microsoft Windows 2000 - Service Pack 4* US and European languages onlyPrivileges:* To install and run the Secunia PSI you will need administrative privilegesConnectivity:* Access to Secunia servers (encrypted) via SSL (https://psi.secunia.com:443/)* Access to Microsoft Windows Update servers, see also WUA requirements belowSoftware Requirements:* Latest version of Microsoft Windows Update Agent (WUA)You can determine whether or not you are running the latest WUA by visiting "http://windowsupdate.microsoft.com/". If you are able to check your system for missing updates through this tool, your system should function properly with the Secunia PSI.Homepage & Download
