  • geodasoft changed the title to Adobe Components 05.06.2021 Desatendido Multi
  • Replies 55
  • Views 27.1k
  • geodasoft changed the title to Adobe Components 07.07.2021 Desatendido Multi
Adobe AIR 33.1.1.533 New
No se si estan de acuerdo  en la proxima version en añadir
MSXML.4.0.SP3.Parser
Visual.F..4.1.SDK.Silent
Legacy.VB.C.Runtime.Libraries.
  • geodasoft changed the title to Adobe Components 21.07.2021 Desatendido Multi
  • geodasoft changed the title to Adobe Components 21.10.2021 Desatendido Multi x86 & x64
  • geodasoft changed the title to Adobe Components 20.01.2022 Desatendido Multi x86 & x64
What’s New in Adobe AIR 33.1.1.821:
Updated iOS handling of URL sessions to support self-signed certificate confirmations
Ensuring ADL checks under ~/.airsdk for a license file
Adding device model to Android OS version information (unless opting out)
AIR Android APK camera roll permission problem
Fixing resizing of direct-mode canvas on orientation change
Preventing flicker of menu/doc on macOS fullscreen app launch
Removing legacy dependency on dsound.dll to fix Win11 runtime failure
Updating Android clipboard implementation for new API
Enabling video textures for AIR on Linux
Changing macOS native signing check to be case-insensitive
Updating failfast implementation to avoid import of RaiseFailFaseException
  • geodasoft changed the title to Adobe Components 11.04.2022 Desatendido Multi x86 & x64
  • geodasoft changed the title to Adobe Components 20.04.2022 Desatendido Multi x86 & x64
  • geodasoft changed the title to Adobe Components 02.05.2022 Desatendido Multi x86 & x64
  • geodasoft changed the title to Adobe Components 20.07.2022 Desatendido Multi x86 & x64
  • geodasoft changed the title to Adobe Components 02.09.2022 Desatendido Multi x86 & x64
What’s New in Adobe AIR 33.1.1.929:
  • Reverting the merging of ABC blocks in SWCs
  • Sending ByteArray from Worker cause Adobe Scout show incorrect memory consumption
  • Cleaning up local JNI references to avoid Java OutOfMemory errors
  • Allowing the app descriptor to limit the Direct3D version level (using a new descriptor option ” under the section)
  • Fixing runtimeClases.jar file format to remove directory entries, and enabling jetifier
  • Removing exe and dll files from the Linux and macOS SDK zips
  • Reworking omit-trace-statements to ensure the compiler still works within Flash Builder
  • Fixing error in Rectangle.unionToOutput if ‘this’ object is the same as ‘output’ parameter
  • Adding ‘ignore’ option for autoOrients to avoid using OrientationEventListener
  • Release 33.1.1.926 ignored autoOrients configuration value
  • Release 33.1.1.926 ignored stage.setAspectRatio request
  • geodasoft changed the title to Adobe Components 18.10.2022 Desatendido Multi [x86/x64]
  • geodasoft changed the title to Adobe Components 18.01.2023 Desatendido Multi [x86/x64]
  • geodasoft changed the title to Adobe Components 24.02.2023 Desatendido Multi [x86/x64]
  • geodasoft changed the title to Adobe Components 20.04.2023 Desatendido Multi [x86/x64]
  • geodasoft changed the title to Adobe Components 20.07.2023 Desatendido Multi [x86/x64]
  • geodasoft changed the title to Adobe Components 01.12.2023 Desatendido Multi [x86/x64]
  • geodasoft changed the title to Adobe Components 09.07.2024 Desatendido Multi [x86/x64]
