hi
i just cant seem to figure out what commands to use in wpi to get my custom settings to copy from cd to program files. what is the code to copy from cd to program files in wpi.
please help me'
hi
i need help on how to import registry tweaks through wpi
what code or how shall i write the command in wpi to import my registry tweaks. please help
hi ricks
yes i did try the above method, it did not work. any other solution or maybe nlite. by the way i only use wpi, not the winnt.sif to run reg files. and if i do use winnt.sif, how do i run the reg.files
hey kels
thanx so much, yes the problem was double qutoes, now i removed it and everything is working fine now.
thanks for your help
