Posted August 7, 200717 yr CodecInstaller is an application that detects which Audio&Video codecs are installed on your computer and suggests you to install the ones necessary to correctly view the movie it is distributed with: in fact it's designed to be burned on a CD together with a compressed video, to be always able to play them.The users who receive the CD, with a single tool with a simple and intuitive interface, can check if the necessary codecs are already installed and up-to-date and with just a click can install the ones required.Fize Size:667KBLanguage:EnglishOS:Win2000/XP/2003 Date added:July 14,2007License:Free WEB:http://www.jockersoft.com/codecinstaller_index.phpdownload here
August 8, 200717 yr Author Thanks Cro-Man that's a great tool and I'm dl it right now :thumbsup_anim:Ich habe es ausprobiert,es ist klein und tut genau dass wofuer es gedacht ist.
