Hector Posted August 8, 2007 Posted August 8, 2007 Every Startup my icons are large but then they turn normal size. Everytime when my sidebar appears. Is there any patch or anything to fix this problem? Quote
ricktendo Posted August 8, 2007 Posted August 8, 2007 Are you sure its the sidebar... I have the same problem but its ViStart causing it.BTW what do you use to make the icons bigger, nLite or a 3rd party app?Off Topic: Moved topic to AddOn discussion Quote
Hector Posted August 9, 2007 Author Posted August 9, 2007 Are you sure its the sidebar... I have the same problem but its ViStart causing it.BTW what do you use to make the icons bigger, nLite or a 3rd party app?Off Topic: Moved topic to AddOn discussionNo, i make the desktop icons bigger by right clicking the desktop and click on "Properties" then go to the "Appearance" tab and click on effects and click on "use large icons" then apply Quote
