umm this should be in the svcpack addons section,and thers a couple things you should change in the way u add the programm to svcpack.you dont need to include the install.reg in the svcpack as it is in the sfx archive could be imported to the registry via the sfx comment.(Setup=regedit /s install.reg).and speaking of the sfx archive comment, you should change it like this:
Path=%systemdrive%\Program Files\
Setup=regedit /s "%systemdrive%\Program Files\Madotate_2.02.02\install.reg"
SavePath
Silent=1
Overwrite=1
Shortcut=P, "%systemdrive%\Program Files\Madotate_2.02.02\madotate.exe", "Desktop","", "Madotate"
Shortcut=D, "%systemdrive%\Program Files\Madotate_2.02.02\madotate.exe","","", "Madotate"
and in ure entries.ini u can take out the line that was importing the .reg file.(in fact u dont even need the keys in the reg entry,unless u want custom setting s to be applied)
and one last thing,you should add "addon" to ure svcpack addon(MADOTATE_2.02.02_ADDON.CAB)so it gets picked up by the ryan vm integrator.
  • 9 months later...
