August 12, 200717 yr It tells the integrator to compress the file before putting into the I386 dir.Please try to use better topic titles! Titles that are so generic are usually just ignored.
August 12, 200717 yr Author [RESTORE_OOBE_ACTIVATE_STARTMENU]Name = %oobe_desc%CmdLine = 11,,"%%SYSTEMROOT%%system32oobemsoobe.exe /A"SubDir = %startmenucommon%InfoTip = "@%SystemRoot%system32oobemsoobe.exe,-2001"DisplayResource="%SystemRoot%system32oobemsoobe.exe",2000Detailed explanations? 啊
August 12, 200717 yr Thats a ProfileItem a.k.a. Shortcut.I see you are intrested in learning how to make addons. Here is a INF guide that might helphttp://www.sokoolz.com/addons/r64/INF_DOC.zip
August 12, 200717 yr Author A logical disk identifier (LDID). Can be one of these values: Value Meaning 00 Null LDID. This LDID can be used to create a new LDID 01 Source Drive:\pathname 10 Machine directory (Maps to the Windows directory on a Server-Based Setup.) 11 System directory 12 IOSubsys directory 13 Command directory 17 INF Directory 18 Help directory 20 Fonts 21 Viewers 22 VMM32 23 Color directory 24 Root of drive containing the Windows directory 25 Windows directory 26 Guarenteed boot device for Windows (Winboot) 28 Host Winboot 30 Root directory of the boot drive 31 Root directory for Host drive of a virtual boot drive Not only these ???
August 12, 200717 yr You use those for DestinationDirs to tell the INF where to copy the filesRead my INF Theme Tutorial maybe it will explain a little http://www.wincert.net/forum/index.php?showtopic=800
August 13, 200717 yr Author [DestinationDirs]Theme.File = 16440,"Themes" 16440 = %WinDir%\Resources %HOMEDRIVE%\Program Files = ?
August 13, 200717 yr I know you need help understanding some of this but you need to do some research.Read the attached pdf file.
August 13, 200717 yr You will never learn like this... You have to be around the forums for a while and you have to look at other addons and see how they are made.
