ricktendo Posted August 16, 2007 Share Posted August 16, 2007 Styler v1.401Info: Style Change Application. Includes Royale, Frost, Vista Classic, Vista Styler skins.MD5: 9ACB61DA0446124B5AE8D3B21D81065CSize: 816 KBWebsite: http://www.crystalxp.net/galerie/en.id.551-styler-1-401.htmlOff Topic: If you have a favorite styler skin and want it added to the addon, post a link and if I like it may add it. Quote Link to comment Share on other sites More sharing options...
ss_tekin Posted August 16, 2007 Share Posted August 16, 2007 thank you very very much ricktendo64 Quote Link to comment Share on other sites More sharing options...
ricktendo Posted August 16, 2007 Author Share Posted August 16, 2007 Let me know how it worked, the msi is not svcpack compatible so I use a INF trick to install it via runonceex then delete the installer.If you have any more cool skins post links I may add them. Quote Link to comment Share on other sites More sharing options...
ss_tekin Posted August 18, 2007 Share Posted August 18, 2007 styler toolbars skins http://rapidshare.com/files/49767666/style...s_skin.rar.html Quote Link to comment Share on other sites More sharing options...
bober Posted August 18, 2007 Share Posted August 18, 2007 hey rick, is there a way to remove styler from startup after 1st run via ure addon?cuz after its ran and done its thing, we dont need it to load and apply settings after each reboot,settings stay.but this brings me with one question, wouldint it be possible to just run styler.exe via runonce?or does the .exe export after its ran an entrie to send it to startup? Quote Link to comment Share on other sites More sharing options...
JurgenDoe Posted August 19, 2007 Share Posted August 19, 2007 hey rick, is there a way to remove styler from startup after 1st run via ure addon?cuz after its ran and done its thing, we dont need it to load and apply settings after each reboot,settings stay.but this brings me with one question, wouldint it be possible to just run styler.exe via runonce?or does the .exe export after its ran an entrie to send it to startup?Just use go to Start-->Run-->msconfig-->Startup and disable the styler from the startup. Reboot and styler will not show up again in your startupHope this helps :icon_rolleyes: Quote Link to comment Share on other sites More sharing options...
bober Posted August 19, 2007 Share Posted August 19, 2007 well that would be missing the point of having an unattended install. Quote Link to comment Share on other sites More sharing options...
ricktendo Posted August 19, 2007 Author Share Posted August 19, 2007 I understand what you want m8 don't worry... You can add this command to the INF (if you have the nerve)[Del.Installer]CMD /Q /C DEL %10%\StylerTB.exe /Q /FCMD /Q /C DEL """%16391%\Styler.lnk""" /Q /F;<- Add this lineAdd that line and the startup link will be deleted at the same time as the silent runonceex installer is. Quote Link to comment Share on other sites More sharing options...
bober Posted August 23, 2007 Share Posted August 23, 2007 hey thx man ,really apreciate it. Quote Link to comment Share on other sites More sharing options...
anonymous Posted October 5, 2007 Share Posted October 5, 2007 Thanks for this addon Rick.The theme I use is Tango Styler Toolbar XPmod 2.0. Quote Link to comment Share on other sites More sharing options...
ENU_user Posted October 13, 2007 Share Posted October 13, 2007 (edited) some Dark Toolbarsfrom: visualstyle-themesbtw, can hardly see anything in this new Halloween design :crying_anim02: Edited October 13, 2007 by ENU_user Quote Link to comment Share on other sites More sharing options...
ricktendo Posted October 13, 2007 Author Share Posted October 13, 2007 btw, can hardly see anything in this new Halloween design :crying_anim02:You can change it Quote Link to comment Share on other sites More sharing options...
yadzil Posted November 26, 2007 Share Posted November 26, 2007 Hi ricks, I got Msg " Cannot find X:\Iexplore.vbs" when I try access my harddisk drive other than system drive. Does thiss addon can make this problem happened? Quote Link to comment Share on other sites More sharing options...
ricktendo Posted November 26, 2007 Author Share Posted November 26, 2007 Not sure. Quote Link to comment Share on other sites More sharing options...
MzQueenie Posted November 29, 2007 Share Posted November 29, 2007 (edited) edit: works fine Edited November 29, 2007 by MzQueenie Quote Link to comment Share on other sites More sharing options...
stsaerox Posted June 19, 2009 Share Posted June 19, 2009 Rick can you tell me how to add windows 7 style and use this as default on my unattended installation? Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 19, 2009 Author Share Posted June 19, 2009 Well in the newer one for Spanish XP I did a admin install, edited StylerTB.ini with the default skin, used InstallShield to add the skin files to the msi installer and finally the add the reg entry to the msi to turn styler on by defaulthkcu\Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser Quote Link to comment Share on other sites More sharing options...
stsaerox Posted June 19, 2009 Share Posted June 19, 2009 (edited) Can I just add my windows 7 style in StylerTB.exe (in: StylerTB.exe\TB\skins\Styler's) and my modded stylerTB.ini with windows 7 style default (in: StylerTB.exe\TB) of this addon? Will that work? Or I have to update stylerTB.inf entries and stylerTB.cab with win 7 style files?This reg entry that you are mentioning, I think that's already enabled and more exteded in your stlylerTB.inf.If I succesfully make it can I upload this there for anyone who need this? Edited June 19, 2009 by stsaerox Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 19, 2009 Author Share Posted June 19, 2009 Yes you can do that, dont add the skin to the installer jujst the cab and inf, that will only work/copy if you use InstallShileld to edit the msi to add it Quote Link to comment Share on other sites More sharing options...
stsaerox Posted June 19, 2009 Share Posted June 19, 2009 I've already updated the inf file but I don't know how to add StylerTB.ini in my installation I tried winrar but It doesn't work. Where is installshield how can I open it?Also, is the inf correct?;ricktendo64 2007[Version]Signature=$Windows NT$[Optional Components]Styler ToolBar[DefaultInstall]CopyFiles=Vista.Styler,Vista.Classic,Royale.Skin,Frost.Skin,Windows.7,Installer.Ex,INF.FileAddReg =RunOnceEx.AddReg[Styler ToolBar]OptionDesc ="Styler ToolBar"Tip ="Includes Skins"Modes =0,1,2,3CopyFiles =Vista.Styler,Vista.Classic,Royale.Skin,Frost.SkinAddReg =RunOnceEx.AddReg[SourceDisksNames.x86]1="Styler TB Skin Files","StylerTB.cab",,"i386"[DestinationDirs]Windows.7 =16422,%WINDOWS_7%Vista.Styler =16422,%VISTA_S%Vista.Classic=16422,%VISTA_C%Royale.Skin =16422,%ROYALE%Frost.Skin =16422,%FROST%Installer.Ex =10INF.File =17[SourceDisksFiles]back.png=1bkg.png=1bkgIE.png=1customize.png=1Details.png=1explorer.png=1Favorites.png=1forward.png=1frback.png=1frbkg.PNG=1frDetails.png=1frexplorer.PNG=1frfolders.PNG=1frforward.png=1fricon.png=1frlist.png=1frNew.PNG=1froption.png=1frSearch.png=1frthumbnails.png=1frtile.png=1frtoolbar.ini=1frtree.png=1frup.png=1history.png=1home.png=1icon.png=1IE.png=1list.png=1option.png=1print.png=1refresh.png=1roback.png=1robkg.png=1robkgIE.png=1rocustomize.png=1roDetails.png=1roexplorer.png=1roFavorites.png=1roforward.png=1rohistory.png=1rohome.png=1roicon.png=1roIE.png=1rolist.png=1rooption.png=1roprint.png=1rorefresh.png=1roSearch.png=1roSearchbar.png=1roSearchOption.png=1rostop.png=1rothumbnails.png=1rotile.png=1rotoolbar.ini=1rotree.png=1roup.png=1rozoom-.png=1rozoom+.png=1Search.png=1Searchbar.png=1SearchOption.png=1stop.png=1thumbnails.png=1tile.png=1toolbar.ini=1tree.png=1up.png=1vcback.png=1vcbkg.png=1vcDetails.png=1vcexplorer.png=1vcforward.png=1vcicon.png=1vclist.png=1vcoption.png=1vcsearch.png=1vcthumbnails.png=1vctile.png=1vctoolbar.ini=1vctree.png=1vcup.png=1zoom-.png=1zoom+.png=1[Windows.7]back.png,w7back.pngbkg.png,w7bkg.pngDetails.png,w7Details.pngexplorer.png,w7explorer.pngfolderoption.PNG,w7folderoption.PNGforward.png,w7forward.pngicon.png,w7icon.pnglist.png,w7list.pngnewfolder.png,w7newfolder.pngoption.bmp,w7option.bmpOrganize.PNG,w7Organize.PNGpreviewpane.png,w7previewpane.pngSearch.bmp,w7Search.bmpthumbnails.png,w7thumbnails.pngtile.png,w7tile.pngtoolbar.ini,W7toolbar.iniup.png,w7up.png[Vista.Styler]back.pngbkg.pngbkgIE.pngcustomize.pngDetails.pngexplorer.pngFavorites.pngforward.pnghistory.pnghome.pngicon.pngIE.pnglist.pngoption.pngprint.pngrefresh.pngSearch.pngSearchbar.pngSearchOption.pngstop.pngthumbnails.pngtile.pngtoolbar.initree.pngup.pngzoom-.pngzoom+.png[Vista.Classic]back.png,vcback.pngbkg.png,vcbkg.pngDetails.png,vcDetails.pngexplorer.png,vcexplorer.pngforward.png,vcforward.pngicon.png,vcicon.pnglist.png,vclist.pngoption.png,vcoption.pngsearch.png,vcsearch.pngthumbnails.png,vcthumbnails.pngtile.png,vctile.pngtoolbar.ini,vctoolbar.initree.png,vctree.pngup.png,vcup.png[Royale.Skin]back.png,roback.pngbkg.png,robkg.pngbkgIE.png,robkgIE.pngcustomize.png,rocustomize.pngDetails.png,roDetails.pngexplorer.png,roexplorer.pngFavorites.png,roFavorites.pngforward.png,roforward.pnghistory.png,rohistory.pnghome.png,rohome.pngicon.png,roicon.pngIE.png,roIE.pnglist.png,rolist.pngoption.png,rooption.pngprint.png,roprint.pngrefresh.png,rorefresh.pngSearch.png,roSearch.pngSearchbar.png,roSearchbar.pngSearchOption.png,roSearchOption.pngstop.png,rostop.pngthumbnails.png,rothumbnails.pngtile.png,rotile.pngtoolbar.ini,rotoolbar.initree.png,rotree.pngup.png,roup.pngzoom-.png,rozoom-.pngzoom+.png,rozoom+.png[Frost.Skin]back.png,frback.pngbkg.PNG,frbkg.PNGDetails.png,frDetails.pngexplorer.PNG,frexplorer.PNGfolders.PNG,frfolders.PNGforward.png,frforward.pngicon.png,fricon.pnglist.png,frlist.pngNew.PNG,frNew.PNGoption.png,froption.pngSearch.png,frSearch.pngthumbnails.png,frthumbnails.pngtile.png,frtile.pngtoolbar.ini,frtoolbar.initree.png,frtree.pngup.png,frup.png[Installer.Ex]StylerTB.exe[INF.File]StylerTB.inf[RunOnceEx.AddReg]HKLM,"%RUNONCEEX%\Setup","StylerEx",,"REG ADD ""HKLM\%RUNONCEEX%\Styler"" /V ""StylerTB"" /T REG_SZ /D ""RUNDLL32 advpack.dll,LaunchINFSection StylerTB.inf,Toolbar.Install"""[Toolbar.Install]RunPreSetupCommands =Styler.SetupAddReg =TB.SettingsRunPostSetupCommands=Del.Installer:1[Styler.Setup]%10%\StylerTB.exe[TB.Settings];HKCU,"Software\Microsoft\Internet Explorer\Toolbar","Locked",0x10001,01,00,00,00HKCU,"Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser","ITBarLayout",1,11,00,00,00,4c,00,00,00,00,00,00,00,24,00,00,00,18,00,02,00,5b,00,00,00,01,00,00,00,a0,06,00,00,a0,0f,00,00,02,00,00,00,a9,06,00,00,a0,0f,00,00,07,00,00,00,a1,04,00,00,a9,00,00,00,04,00,00,00,a9,00,00,00,51,03,00,00,05,00,00,00,6a,04,00,00,26,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,19,f9,f8,d2,0b,69,a2,4e,9f,a7,a2,03,d1,e0,4f,75,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00[Del.Installer]CMD /Q /C DEL %10%\StylerTB.exe /Q /F[Strings]WINDOWS_7="Styler\TB\skins\Styler's\Windows 7"VISTA_S ="Styler\TB\skins\Styler's\Vista Styler"VISTA_C ="Styler\TB\skins\Styler's\Vista Classic"ROYALE ="Styler\TB\skins\Styler's\Royale"FROST ="Styler\TB\skins\Styler's\Frost"RUNONCEEX="SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx"I've also renamed the skin's files Quote Link to comment Share on other sites More sharing options...
stsaerox Posted June 25, 2009 Share Posted June 25, 2009 (edited) Ricktendo64 can you tell me please if I can add the default style in the inf entries? Edited June 25, 2009 by stsaerox Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 25, 2009 Author Share Posted June 25, 2009 Yes (I have no idea what you are asking) Quote Link to comment Share on other sites More sharing options...
stsaerox Posted June 25, 2009 Share Posted June 25, 2009 I want to add the command in the StylerTB.inf commands, to change the default styler's toolbar.I want to add windows 7 style as default not the frost. Is that possible by entering commands in StylerTB.inf? Quote Link to comment Share on other sites More sharing options...
ricktendo Posted June 25, 2009 Author Share Posted June 25, 2009 Its embedded in the installer TB\StylerTB.ini but I guess I can edit it using the INF file, try adding this to the INF to edit the ini[Styler ToolBar]OptionDesc ="Styler ToolBar"Tip ="Includes Skins"Modes =0,1,2,3...UpdateInis=Def.Skin[Def.Skin]%16422%\Styler\TB\StylerTB.ini,StylerTB,,skin=Styler's\FrostOf course you change Frost with the name of the skin you want Quote Link to comment Share on other sites More sharing options...
stsaerox Posted June 25, 2009 Share Posted June 25, 2009 Thanks Ricktendo64 I'll try that soon Quote Link to comment Share on other sites More sharing options...
