Posted March 17, 20205 yr WinToolkit ver. 1.7.0.14 Host/PC OS: Windows 10 (64-bit) v1909 OS that is being modified: Windows 7 (32-bit) Ultimate I keep trying to integrate IE11 into this system but no luck, it bugs and shows the error like in attachment. I tried doing same on x64 version of W7Ultimate and it goes with no problem, configuration and updates are same (only 64bit version)
March 17, 20205 yr Author Also, additional thing I have noticed is that RunOnce stops working during firs run, just like shown on picture below. Again, only happens on x86 integration of Windows 7 Ultimate (SP1 version)
March 17, 20205 yr Author 8 hours ago, linkservis said: Also, additional thing I have noticed is that RunOnce stops working during firs run, just like shown on picture below. Again, only happens on x86 integration of Windows 7 Ultimate (SP1 version) So it turns out that RunOnce error happens at both x86 and x64 versions, tho I do not use RunOnce so its a bit confusing. But IE11 slipstreams into X64 Win7 with no problems, but fails with X86. Also tried previous versions of Win Toolkit that I know worked, and they also fail. I presume its something to do with new Win10 v1909. I will try on virtual machine that has W7x64 and see how it goes.
March 25, 20205 yr Author Just did exactly the same thing on VirtualBox machine with W7x64 as guest OS, and it integrated with no errors or problems. It seems to be an issue with W10x64U1909
March 27, 20205 yr i guess there may be some bugs in W10x64U1909. I am aware of quick swap from 1903 and 1909 and not talking about that. I also have experience of upgrading from any build to any build in the past (we are evaluating this stuff in a lab all the time) and upgrading to 1909 takes the longest time I ever seen. I have been doing this from 2015 and hardware is almost the same. With HDD it takes 5-6 hours, with SDD it took 3 hours.
