Converber
Converber is a unit converter. It is a powerful software utility that will help make easy conversions between 1241 various units of measure in 33 categories. Converber converts everything from length and force to flow and temperature. See some of the features listed below.
* Gives immediate access to all categories or single category
* Favorites menu to bookmark your frequently-used conversions
* Currency rates...updated daily
* New! Inline calculator(*/-+^ and more)
* Automatic updates
* Quickly search the unit list and immediately see results
* Step backwards or forwards through the most recently used conversions
* Single or multiple preference file(s) for different users
* Shows either common units or ALL units
* Converts as you type, so no convert button is required
* Includes equation editor to add your own custom units
* Allows you to select/unselect the conversion file(s)
* Can change the number of significant digits of the output
* Option to select decimal-point precision
* Option to select scientific notation only
* Extensive number formatting
* Inverts selected units with the quick swap feature
* Displays the category to give further information
* Converts left-to-right OR right-to-left
* Runs portable/stand-alone using no dll files or registry settings
* Remembers last window position and size (if desired)
* Offset correction for meter value compensation
* Comes with extensive help file
* Supports transparency (Windows 2000, XP only)
* Supports a multi-language user interface
* And more...
size.png@244 KB
md5.png B68A55926F813AE74228F6DE1DC8CC0A
Note: Shortcut (destination directory) can be found under Utilities
Changelog:
20- November - 08 - Updated to version 1.8.0,moved under Utilities section
8 - November - 07 - Updated to version 1.6.0
17-August-07 - first release...includes add/remove entries.
Edited by Gorki
I'm glad you guys like it. I did update database before I made addon. You can also update it from time to time throu program menu. It's quite easy
  • 1 year later...
thank you for this important tool
this link for updated converter v1.8
http://rapidshare.com/files/165029965/Gorki_AddOn_Converber180.7z
Edited by ehabfg
