hi all,
could you please tell me how to change the text (bitmap) from the start button left panel.
Instead of having "windows xp professional" i would like to have my text/ bitmap.
is there any addon for this?
would be appreciable for any help.
Shafaet...
Edited by shafaet
You mean the classic start menu right?
If you open EXPLORER.EXE in Reshacker the resource address is Bitmap>167, simply replace the bitmap with another of the same dimension.
You may need to copy explorer.exe someplace on your desktop, replace the bitmap and use Replacer to swap old explorer for new one
thanks a lot rick, i played with reshack, and able to change those bitmaps 167.
but is there any way i can make this as an addon so, i don't have to do the resh hack stuff every time i install windows xp.
thanks for your help.
shafaet
