Posted April 13, 20204 yr Hi, I downloaded Win7 w/SP1 x64 german ISO directly from Microsoft and used WinToolkit 1.7x to integrate all the updates, .net-Runtimes etc. Most of the updates I downloaded using whdownloader, but the missing ones I added by downloading them from ms update catalog (.net and c runtimes as Addon from this site). After installation Windows Updates tells me it needs to install SP1 with about 9MB of size?!? 2019-10 cumulative update KB4524752 and security update KB3046269 are missing too, but I added them to the update-list. Any idea on how to fix this issue? Thank you!
April 14, 20204 yr Author Thank you, but where in this thread is the solution? I don't understand french, it's such a weird language And there are over 100 pages in this thread 🥺
April 14, 20204 yr @Troubadix Just check the tutos at the end of the first post of the tread, one is written in German. The 9 MB of Windows SP1 is due to obsolete KB2533552. Some updates need to be hidden in WU because of a bug, this is the reason why some are requested even your ISO is up-to-date. All needed material is in the fist post.
April 14, 20204 yr 21 hours ago, Troubadix said: Most of the updates I downloaded using whdownloader 21 hours ago, Troubadix said: (.net and c runtimes as Addon from this site) You should've stopped there. Windows 7 has a lot of obsolete updates and/or updates that are only required to make Windows Update client happy. If you're making your own up-to-date iso, using Windows Update after installation is, imo, pointless.
April 14, 20204 yr Author 1 hour ago, rhahgleuhargh said: @Troubadix Just check the tutos at the end of the first post of the tread, one is written in German. The 9 MB of Windows SP1 is due to obsolete KB2533552. Some updates need to be hidden in WU because of a bug, this is the reason why some are requested even your ISO is up-to-date. All needed material is in the fist post. Thank you, I didn't noticed the tutorials at first read. Will give this a try. "tuto de april" doesn't sound much like "Tutorial in German". @shhnedo: I'm using WU to check if everything is up to date while testing. When I'm ok with the ISO I will not use this.
April 14, 20204 yr 7 hours ago, Troubadix said: "tuto de april" doesn't sound much like "Tutorial in German". I've changed it.
