Posted August 19, 200717 yr CL-Tools 4Win is a free suite of user interfaces for several command line utilities otherwise available only in DOS Mode. These four are used often here and I thought I would make them available to anyone that might have use for them. The suite includes GUIs for Microsofts CDImage, Cabarc, MakeCab and UPX by Markus F.X.J. Oberhumer, László Molnár and John F. Reiser.CDImage 4WinThe purpose of CDIMAGE is to generate an ISO CD/DVD image from the contents of a folder on the hard drive. There are options which can control various ISO image's properties like volume label, time stamp, optimize storage, boot sector file and more. If you have a CD with multiple software versions, you can author a CD that will only write the same files once, so the same physical content on the CD/DVD can appear in multiple directories while saving a substantial amount of space. It will also create bootable images of Operating Systems Windows 98, Millennium, NT, Windows 2000, Media Center Edition, XP, Windows 2003 and Vista applying the Boot Sector files and Volume label. (Boot files included)Cabarc 4WinCabarc is a utility that creates and extracts cabinet files. The cabinet format provides a way to efficiently package multiple files. The key features of the cabinet format are that multiple files may be stored in a single cabinet and that data compression is performed across file boundaries, significantly improving the compression ratioMakeCab 4WinMakeCAB is a data compression tool that can be to compress or extract Windows Setup Cab files such as .dl_ .ex_ .sy_ .bm_ .oc_ .gi_ .wa_ .mi_, etc. Although it was originally designed for use by setup programs, it can also be used in almost any situation where lossless data compression is required.UPX 4WinUPX is a portable, extendable, high-performance executable packer for several different executable formats. It achieves an excellent compression ratio and offers *very* fast decompression.Download
