pawelnrg Posted June 2, 2020 Share Posted June 2, 2020 (edited) im dont know it help but: IE instaled OK. but NET F. not. Edited June 2, 2020 by pawelnrg Quote Link to comment Share on other sites More sharing options...
pawelnrg Posted September 6, 2020 Author Share Posted September 6, 2020 (edited) self answer: YOU NEED integrate add-on: exactly that one : translated from German: "For Windows 7, at least .NET Framework 4.7.2 should be installed. This also applies to the WinToolkitRunOnce. Microsoft .NET Framework for Windows 7 add-on from abbodi1406 should be integrated, otherwise it will not start." Edited September 6, 2020 by pawelnrg Quote Link to comment Share on other sites More sharing options...
pawelnrg Posted September 7, 2020 Author Share Posted September 7, 2020 all work, windows install ok, until try install programs in new windows Error - 1629 Quote Link to comment Share on other sites More sharing options...
ilcaa Posted October 23, 2020 Share Posted October 23, 2020 I am running into the same problems. My RunOnce keep errorring. On .Net 4.8 install and even on silent install of 7zip. for .NET48: ndp48-x86-x64-allos-enu.exe /q /norestart for 7zip: /S /D="C:\Program Files\7-Zip" were you able to solve the problem? Quote Link to comment Share on other sites More sharing options...
pawelnrg Posted January 7, 2021 Author Share Posted January 7, 2021 (edited) From mistake what i done....... use N-Sudo.. whoever you think, you need : all in Your windows: framework, mdt... dism..... Download fresh win-toolkit, fresh win update, a fresh ADD-ON + right language, (from https://www.wincert.net/forum/topic/11127-microsoft-net-framework-48-for-windows-7/ set output catalogue - integrate update from "general" "hot-fix" and "security" and "withoutESU " and ADD-ON and go. ALL work for my..... now RunOnce need framework to operate!!! You need use add-on! not sure you can do that specific add-on yourself because of D3DCompiler. (- is included in 4.8 nad no in 4.7) and right for You Language Packs. Edited August 10, 2022 by pawelnrg Quote Link to comment Share on other sites More sharing options...
