January 15, 20223 yr Author Changes in Microsoft Edge 97.0.1072.62 (2022-01-14): Fixed various bugs and performance issues. Changes in Microsoft Edge 97.0.1072.55 (2022-01-06): Feature updates Use the current profile to sign into websites when multiple work or school accounts are signed in on a device. When multiple work or school accounts are signed in on a device, users will be asked to choose an account from the account picker to continue their visits to websites. In this release, users will be prompted to let Microsoft Edge sign in to the websites automatically with the work or school account that’s signed into the current profile. Users can turn this feature on and off in Settings > Profile preferences. Add support for Microsoft Endpoint Data Loss Prevention (DLP) on macOS. Microsoft Endpoint DLP policy enforcement will be available natively on macOS. Automatic HTTPS. Users can upgrade navigations from HTTP to HTTPS on domains likely to support this more secure protocol. This support can also be configured to attempt delivery over HTTPS for all domains. Note: This feature is a Controlled Feature Rollout. If you don’t see this feature, check back as we continue our rollout. Block WebSQL in 3rd-party contexts. Use of the legacy WebSQL feature will be blocked from 3rd-party frames. The WebSQLInThirdPartyContextEnabled policy is available as an opt-out option until Microsoft Edge version 101. This change is happening in the Chromium project that Microsoft Edge is based on. Citations in Microsoft Edge. Citing sources for research is a common requirement for students. They have to manage many research references and sources, which aren’t easy tasks. They also have to translate these citations to proper citation formats like APA, MLA, and Chicago. This new “Citations” feature, now in Preview in Microsoft Edge, gives students a better way to manage and generate citations as they research online. With Citations turned on in Collections or from Settings and more (Alt-F), Microsoft Edge automatically generates citations that students can use later so they can stay focused on their research. When they’re done, they can easily compile these citations into a final deliverable. Control Flow Guard (CFG). Microsoft Edge will start supporting more fine-grained protection by combating memory corruption vulnerabilities and by protecting against indirect calls. CFG is only supported with Windows 8 and later. Control-flow Enforcement Technology (CET) available with security feature. When you enable “Enhance your security on the web”, Microsoft Edge will support an even safer browsing mode that uses hardware-dependent control flow for browser processes. CET is available on the following supported hardware: Intel 11th Gen. or AMD Zen 3. New Policies AccessibilityImageLabelsEnabled – Get Image Descriptions from Microsoft Enabled. ApplicationGuardUploadBlockingEnabled – Prevents files from being uploaded while in Application Guard. AudioProcessHighPriorityEnabled – Allow the audio process to run with priority above normal on Windows. AutoLaunchProtocolsComponentEnabled – AutoLaunch Protocols Component Enabled. BrowserLegacyExtensionPointsBlockingEnabled – Enable browser legacy extension point blocking. CORSNonWildcardRequestHeadersSupport – CORS non-wildcard request header support enabled. CrossOriginWebAssemblyModuleSharingEnabled – Specifies whether WebAssembly modules can be sent cross-origin. DisplayCapturePermissionsPolicyEnabled – Specifies whether the display-capture permissions-policy is checked or skipped. EdgeDiscoverEnabled – Discover feature In Microsoft Edge. EdgeEnhanceImagesEnabled – Enhance images enabled. EfficiencyMode – Configure when efficiency mode should become active. ForceSyncTypes – Configure the list of types that are included for synchronization. InternetExplorerIntegrationComplexNavDataTypes – Configure whether form data and HTTP headers will be sent when entering or exiting Internet Explorer mode. InternetExplorerModeToolbarButtonEnabled – Show the Reload in Internet Explorer mode button in the toolbar. InternetExplorerModeTabInEdgeModeAllowed – Allow sites configured for Internet Explorer mode to open in Microsoft Edge. InternetExplorerIntegrationWindowOpenHeightAdjustment – Configure the pixel adjustment between window.open heights sourced from IE mode pages vs. Edge mode pages. InternetExplorerIntegrationWindowOpenWidthAdjustment – Configure the pixel adjustment between window.open widths sourced from IE mode pages vs. Edge mode pages. IntranetFileLinksEnabled – Allow intranet zone file URL links from Microsoft Edge to open in Windows File Explorer. NewSmartScreenLibraryEnabled – Enable new SmartScreen library. PrintPostScriptMode – Print PostScript Mode. PrintRasterizePdfDpi – Print Rasterize PDF DPI. RendererAppContainerEnabled – Enable renderer in app container. SameOriginTabCaptureAllowedByOrigins – Allow Same Origin Tab capture by these origins. ScreenCaptureAllowedByOrigins – Allow Desktop, Window, and Tab capture by these origins. SerialAllowAllPortsForUrls – Automatically grant sites permission to connect all serial ports. SerialAllowUsbDevicesForUrls – Automatically grant sites permission to connect to USB serial devices. ShadowStackCrashRollbackBehavior – Configure ShadowStack crash rollback behavior. SharedLinksEnabled – Show links shared from Microsoft 365 apps in History. SmartScreenDnsRequestsEnabled – Enable Microsoft Defender SmartScreen DNS requests. TabCaptureAllowedByOrigins – Allow Tab capture by these origins. TyposquattingCheckerEnabled – Configure Edge TyposquattingChecker. VisualSearchEnabled – Visual search enabled. WebSQLInThirdPartyContextEnabled – Force WebSQL in third-party contexts to be re-enabled. WindowCaptureAllowedByOrigins – Allow Window and Tab capture by these origins. Changes in Microsoft Edge 96.0.1054.62 (2021-12-17): Fixed various bugs and performance issues. Changes in Microsoft Edge 96.0.1054.57 (2021-12-14): This update contains a fix for CVE-2021-4102, which has been reported by the Chromium team as having an exploit in the wild. Changes in Microsoft Edge 96.0.1054.53 (2021-12-10): Stable channel security updates
January 30, 20223 yr Author Changes in Microsoft Edge 97.0.1072.76 (2022-01-27): Fixed various bugs and performance issues. Feature updates Upcoming three-digit version number in user agent string. Starting with version 100, Microsoft Edge will send a three-digit version number in the User-Agent header, for example “Edg/100”. Starting with Microsoft Edge 97, site owners can test this upcoming user agent string by enabling the #force-major-version-to-100 experiment flag in edge://flags to ensure their User-Agent parsing logic is robust and works as expected.
February 16, 20223 yr Author Version 98.0.1108.55: February 16 Important This update contains a fix for CVE-2022-0609, which has been reported by the Chromium team as having an exploit in the wild. For more information, see the Security Update Guide. Stable channel security updates are listed here.
February 19, 20223 yr Author Changes in Microsoft Edge 98.0.1108.56 (2022-02-17): Fixed various bugs and performance issues.
February 26, 20223 yr Author Changes in Microsoft Edge 98.0.1108.62 (2022-02-25): Fixed various bugs and performance issues for Stable and Extended Stable release.
March 5, 20223 yr Author Version 99.0.1150.30: March 3 Stable channel security updates are listed here. Feature updates Upcoming three-digit version number in user agent string. Starting with version 100, Microsoft Edge will send a three-digit version number in the User-Agent header, for example "Edg/100". Starting with Microsoft Edge 97, site owners can test this upcoming agent string by enabling the #force-major-version-to-100experiment flag in edge://flags to ensure their User-Agent parsing logic is robust and works as expected. Personalize multi-profile experiences with profile preferences for sites. Users can personalize their multi-profile experience with the ability to create a customized list of sites for automatic profile switching in Microsoft Edge. Navigate PDF documents using page thumbnails. You'll now be able to navigate through your PDF document using thumbnails that represent the pages. These thumbnails will appear in the pane on the left side of the PDF reader. Configure the list of domains for which the password manager User Interface (UI) for Save and Fill will be disabled. Use the PasswordManagerBlocklist policy to configure the list of domains (HTTP/HTTPS schemas and hostnames only) where Microsoft Edge should disable the password manager. This means that Save and Fill workflows will be disabled, which ensures that passwords for those websites can’t be saved or auto filled into web forms. Custom primary password. The browser already has the capability where users can add an authentication step before saved passwords are auto filled in web forms. This adds another layer of privacy and helps prevent unauthorized users from using saved passwords to log on websites. Custom primary password is an evolution of that same feature, where users will now be able to use a custom string of their choice as their primary password. After it's enabled, users will enter this password to authenticate themselves and have their saved passwords auto filled into web forms. Policy updates New Policies DoNotSilentlyBlockProtocolsFromOrigins - Define a list of protocols that can not be silently blocked by anti-flood protection ForceMajorVersionToMinorPositionInUserAgent - Enable or disable freezing the User-Agent string at major version 99 HubsSidebarEnabled - Show Hubs Sidebar InternetExplorerIntegrationCloudNeutralSitesReporting - Configure reporting of potentially misconfigured neutral site URLs to the M365 Admin Center Site Lists app InternetExplorerIntegrationCloudUserSitesReporting - Configure reporting of IE Mode user list entries to the M365 Admin Center Site Lists app PasswordManagerBlocklist - Configure the list of domains for which the password manager UI (Save and Fill) will be disabled RelatedMatchesCloudServiceEnabled - Configure Related Matches in Find on Page SignInCtaOnNtpEnabled - Enable sign in click to action dialog UserAgentReduction - Enable or disable the User-Agent Reduction
March 8, 20223 yr Author Changes in Microsoft Edge 99.0.1150.36 (2022-03-07): Fixed various bugs and performance issues.
March 21, 20223 yr Author Changes in Microsoft Edge 99.0.1150.39 (2022-03-10): Fixed various bugs and performance issues.
March 26, 20223 yr Author Changes in Microsoft Edge 99.0.1150.52 (2022-03-24): Fixed various bugs and performance issues.
