Posted August 24, 200717 yr Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have already installed XP.Tutorial Summary: We're going to use the DISKPART utility on the Vista DVD to shrink the Windows XP partition on the hard disk and create enough space for an installation of Vista. We'll then install Vista and use the EasyBCD utility to modify Vista's bootloader to get XP loading properly.DISKPART can shrink NTFS partitions and it's certainly the more convenient option, but on some systems using DISKPART to shrink the volume will fail, with an vague "Access is denied" error.This may have something to do with different disk controllers, as this was a problem on the AcerPower test system which has a SATA hard drive, but not on the VMWare system which uses a virtual IDE controller. So we'll cover both processes.This tutorial was tested on a VMWare Workstation 6 virtual machine and an AcerPower SK50.Get Started - Using GPartedWe assume that before you start this tutorial, you have backed up the drive (partitions and data) that will host the two operating systems.Your first step will be to modify the Windows XP system partition to make space for Vista using GPartedThe GParted Live CD ISO is available HERE
August 24, 200717 yr Author Thanks a lotI am glad you like itMore on the wayHold your breath for the coming soon!
