Posted September 5, 200618 yr step1: for now lets start out with a work space of 300x300 (make it bigger if you would like). with your gradient tool selected (G) use the settings below and go crazy filling in your background. (just click and drag about 20+ times): step2: after you get your image looking a little something like the image above goto filter > distort > twirl and set the angle to 300. then press ctrl+u select colorize and use the settings below: step 3: duplicate the layer that you have been doing all the editing to and set the mode to overlay. goto filter > distort > twirl and set the angle to 150. then press ctrl+u select colorize and use the settings below: now go to filter > artistic > plastic wrap. use settings below: Highlight Strength: 17 Detail: 9 Smoothness: 7 your final product should look a little something like the image below:Thanks to bock9.netNow remember.... Tutoruals are just GUIDES! They can always be manulipulated to get the look you want. I took it into my own hands and made my own, changeing things around, this is my result.
