1.) Create a new document, 400x400 pixels). Reset your colours to the default settings (D), and use the Clouds Filter (Filter -> Render -> Clouds). Next, use the Radial Blur feature (Filter -> Blur -> Radial Blur). Put the settings as Zoom, 40, and Best.
2.) Next, do Bas Relief (Filter -> Sketch -> Bas Relief). Use the settings, Detail 7, Smoothness 15, Light : Top
Your image should be now looking something similar to this
3.) The next step is to duplicate the layer (Layer -> Duplicate Layer). Name this Layer 'Layer 2'. Now, reselect Layer 1. On Layer 1, use the Chrome tool (Filter -> Sketch -> Chrome) with settings Detail 0, Smoothness 10.
4.) Now, select the duplicate layer, and change the blending mode to Exclusion.
5.) Re-select Layer 1, and go to Image -> Adjustments -> Hue/Saturation.
Click the 'colorize' box in the bottom right hand corner of the Hue/Saturation window. Put the settings as follows, Hue : 211, Saturation : 28, Lightness : +10
6.) In order to make the next step easier, I strongly recommend zooming out to 50%. This is done by selecting the Zoom tool (Z), then zoom out by holding Alt and clicking on the image, or right-clicking then selecting 'Zoom out'.
In order to zoom out to 50%, do the step mentioned above twice.
7.) Now, press Ctrl+T (Transform). Right-Click and select 'Perspective'. Click, hold and drag the bottom-left marker out as far to the left as you can.
8.) Press 'Enter'. You are now finished :)
thanks to Phoenix_AO
Heres mine.....
no chnage, same steps
How about finding some good tuts for PhotoFiltre or PaintShop?
Good idea, if someone has the time and will needed for this I'll gladly create subforum... :thumbsup:
Sure! i found allot! go ahead! i cant wait :D call it "other graphic software tutorials"
one more forum to call my own :D
Go ahead, forums are created :thumbsup:
  • 6 months later...
