   When creating an install image with Wintoolkit/AIOI I have this issue with driver integration where the prog installs a bunch of drivers I didn't select for it, and if I'm not mistaken it includes all of my currently installed drivers which isn't really a problem when building a new image for this system but kind of a pain when building an image for another system.  I guess it doesn't matter since it only installs drivers for devices which are available, but I'm wondering if it can be prevented.
Start with a fresh project > Skip, (No Preset), do not Load Preset in the Preset List. Or make sure to uncheck Drivers in the preset branch if you choose Load Preset.
AFAIK the current installed drivers aren't added, unless you collected them and add them in project along with any other drivers you add.
