Posted September 8, 200717 yr Shell Extensions are in-process COM objects which extends the abilities of Windows operating system. Most shell extensions are automatically installed by the operating system, but there are also many other applications that install additional shell extension components. For example: If you install WinZip on your computer, you'll see a special WinZip menu when you right-click on a Zip file. This menu is created by adding a shell extension to the system.The ShellExView utility displays the details of shell extensions installed on your computer, and allows you to easily disable and enable each shell extension.ShellExView can be used for solving context-menu problems in Explorer environment. For more information, read the following article: Right-click is slow or weird behavior caused by context menu handlers Using ShellExViewThe ShellExView is a standalone executable. It doesn't require any installation process or additional DLLs. Just copy it to any folder you want, and run it. After you run it, wait a few seconds until ShellExView loads all shell extensions items. Homepage: NirSoftDownload ShellExView in Zip fileDownload self-install executable for installing ShellExView with uninstall supportDownload ShellExView for x64
