If you have ever needed to re-install your operating system for any reason and needed it re-installed with all the applications you previously had, you might find this program useful. This program will print off a list of your installed applications so you can keep a reference on paper ready to tick off when you re-install. The software is so easy to use it requires no instructions. Note: This software looks at the windows registry to reference installed programs, and therefore may miss software that does not install itself so it can been seen under "Add/Remove Programs".
http://www.judge-software.co.uk/download/ipp150.zip
