Posted September 13, 200717 yr This freebie cleans a wide variety of junk from your PC, including cookies, temporary Internet files, and unnecessary DLLs.t will help you to clear lots of garbage on your personal computer, and harmful plugins such as BHO, Adware etc.Compatibility: Windows NT/2000/XP/2003 server/Vista.Some key features and descriptions as below:1. it sweeps so many temporary files which contain personal temp-files, Windows's temp-files, Internet trails and Recycled bin files etc. Especially, BHO plugis is same as temp-files and to be processed.2. it sweeps so many registry-rubbish entries which contain non associative files, disabled components so on. Actually, it also provides better backup mechanism, you can easily backup full registry table, when you perform to clear specified registry-rubbish, HackCleaner will automatically help you to backup entry who's being removed.3. Cleans memory for accelerating performance.3. Force processing malicious files and plugins using HackCleaner or HackUnlocker!3. Autorun with the HackCleaner. you will see HackCleaner how to auto-monitor/block BHO plugins, auto-clear specified garbage on time etc. we suggest you put HackCleaner into startup group and make it easy to be run at background, that will be nice work.4. it supports multi-languages.http://www.geekclaw.com/products.html#hackcleaner" target="_blank">Homepage Edited September 13, 200717 yr by cro-man
