Posted September 17, 200717 yr SIW gives detailed information about your computer properties and settings, detailed specs for: • Software: Operating System, Installed Software and Hotfixes, Processes, Services, Users, Open Files, System Uptime, Installed Codecs, Licenses. • Hardware: Motherboard, Sensors, BIOS, CPU, chipset, PCI/AGP, USB and ISA/PnP Devices, Memory, Video Card, Monitor, Disk Drives, CD/DVD Devices, SCSI Devices, S.M.A.R.T., Ports, Printers. • Network: Network Cards, Network Shares, currently active Network Connections, Open Ports. • Tools: Password Recovery, Reveal lost passwords hidden behind asterisks, Product Keys and Serial Numbers (CD Key), MAC Address Changer, Shutdown / Restart. • Real-time monitors: CPU, Memory, Page File usage and Network Traffic. SIW is a standalone utility that does not require installation (Portable Freeware) - one less installed program on your PC as well the fact that you can run the program directly from an USB flash drive, from a floppy, from a network drive or from a domain login script. SIW (System Information for Windows) performs computer configuration analysis and diagnostics. SIW can create a report file (CSV, HTML, TXT or XML), and is able to run in batch mode (for Asset Management, PC Audit, Software Inventory and Hardware Inventory, Software license compliance).http://www.gtopala.com/siw-download.html
September 17, 200717 yr Uh oh, i just need this one at school, "secrets", then i can see my mates' passwords! :iwasbornleet:
November 22, 200717 yr Author System Information for Windows Everything you want to know about your PCSIW 1.72 is available.SIW 1.72 Added "Browser Helper Objects" module. Added "Shell Extensions" module. Updates for Window NT. Bugfixes.SIW 1.71 Added Tools --> Monitor Test module Updated XML Report (mode XSLT/XPath friendly) Updated Video module Updated Audio and Video Codecs module Updated CPU module Updated PCI module Bugfixes
