SpeedFan 4.33
If you need a tool that can change your computer's fan speeds, read the temperatures of your motherboard and your hard disk, read voltages and fan speeds and check the status of your hard disk using S.M.A.R.T. or SCSI attributes, then you came to the right place. SpeedFan is the software to go. It is fully configurable and you can create custom events to handle every situation in an automated way. SpeedFan works under Windows 9x, ME, NT, 2000, 2003, XP and Vista. SpeedFan works fine on Vista 64 bit too. The relevant driver is now signed with my digital certificate. And this all costs you absolutely nothing!
The latest version is SpeedFan 4.33. Some tools (like Norton Internet Security or ZoneAlarm) may interfere with the software download process. Basically, the REFERER field must be properly sent to SpeedFan's new server. Download won't work if any tool blocks it. For WebMasters: if you do not want to mirror the download locally to your website, please link to http://www.almico.com/speedfan.php and not to the direct download as it won't work. Thank you for your cooperation.
Homepage
Edited by cro-man
