ShellExView v1.18 - Shell Extensions Manager
Description
Shell Extensions are in-process COM objects which extends the abilities of Windows operating system. Most shell extensions are automatically installed by the operating system, but there are also many other applications that install additional shell extension components. For example: If you install WinZip on your computer, you'll see a special WinZip menu when you right-click on a Zip file. This menu is created by adding a shell extension to the system.
The ShellExView utility displays the details of shell extensions installed on your computer, and allows you to easily disable and enable each shell extension.
ShellExView can be used for solving context-menu problems in Explorer environment. For more information, read the following article: Right-click is slow or weird behavior caused by context menu handlers
ShellExView is also available in other languages. In order to change the language of ShellExView, download the appropriate language zip file, extract the 'shexview_lng.ini', and put it in the same folder that you Installed ShellExView utility.
Homepage & Download
