September 23, 200719 yr ShellMenuView is a small utility that display the list of static menu items that appeared in the context menu when you right-click a file/folder on Windows Explorer, and allows you to easily disable unwanted menu items.System RequirementsShellMenuView works properly on Windows 2000 and Windows XP. You can also use ShellMenuView on Windows 98 for viewing the menu items list, but the disable/enable feature won't work on this version of Windows. (The disabling feature is achieved by adding 'LegacyDisable' key to the desired menu item in the Registry, and this Registry key is not supported by Windows 98)Using ShellMenuViewShellMenuView doesn't require any installation process or additional DLLs. In order to start using it, just copy the executable file (shmnview.exe) to any folder you like, and run it.The main window of ShellMenuView displays the list of menu items. You can select one or more menu item, and enable/disable them.LicenseThis utility is released as freeware. You are allowed to freely distribute this utility via floppy disk, CD-ROM, Internet, or in any other way, as long as you don't charge anything for this. If you distribute this utility, you must include all files in the distribution package, without any modification !DisclaimerThe software is provided "AS IS" without any warranty, either expressed or implied, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The author will not be liable for any special, incidental, consequential or indirect damages due to loss of data or any other reason.Translating ShellMenuView to other languagesIn order to translate ShellMenuView to other language, follow the instructions below: 1. Run ShellMenuView with /savelangfile parameter: shmnview.exe /savelangfile A file named shmnview_lng.ini will be created in the folder of ShellMenuView utility. 2. Open the created language file in Notepad or in any other text editor. 3. Translate all string entries to the desired language. Optionally, you can also add your name and/or a link to your Web site. (TranslatorName and TranslatorURL values) If you add this information, it'll be used in the 'About' window. 4. After you finish the translation, Run ShellMenuView, and all translated strings will be loaded from the language file. If you want to run ShellMenuView without the translation, simply rename the language file, or move it to another folder. ShellMenuView is also available in other languages. In order to change the language of ShellMenuView, download the appropriate language zip file, extract the 'shmnview_lng.ini', and put it in the same folder that you Installed ShellMenuView utility.HomepageDownload ShellMenuView
