Posted September 27, 200717 yr Disk fragmentation leads to system slowdowns, PC crashes, slow startup and shutdown and sometimes to system failures. Auslogics Disk Defrag Edited September 27, 200717 yr by cro-man
September 27, 200717 yr What do you think about this software? Would you prefer it over O&O or Magical Defrag etc.
September 27, 200717 yr Author What do you think about this software? Would you prefer it over O&O or Magical Defrag etc.Auslogics Disk Defragmenter is simple and faster to use compared to the standard Windows-included defragmenter. The defragmentation map is easy to read and the program is well suited for today's larger hard drives. Display report shows all files that were defragmented, shows names/ fragments/ clusters/ size and results of files.Supports FAT 16, FAT 32, and NTFS volumes.Does not contain any adware or spyware.Pros: User friendly interface; a little faster than the Windows defragmenter.Cons: No automation features; no option to exclude files or folders,if you are running it on Vista, the interface may look a bit out of place as it preserves the XP looks.Briefly said, simple, reliable and quite fast in actions. The number of skipped files was low, one on the system drive and one on each of the other partitions.It is a good free alternative.
