George King Posted November 15, 2021 Posted November 15, 2021 Please continue here in original Win-Raid discussion UsefulAGKHelper and andrey2049 2 Quote
pappyN4 Posted February 20, 2022 Posted February 20, 2022 (edited) XP64 SP2 + post SP2 update pack Gigabyte B450 Aorus M F52 BIOS AGESA 1.0.0.6 (original F41 AGESA 1.0.0.3 also worked), (booted to XP64 on a different PC with F62d, so maybe Zen3 as well?) Ryzen Zen2 Matisse CPU Issues Restart does not work with XP/XP64 with any of the acpis when using a PS2 keyboard. Have to manually push the restart button. Shutdown works fine. Workaround, use USB keyboard after it is installed (or integrate backported USB3 driver) BIOS Gigabyte B450 Aorus M BIOS settings So I noticed that by default virtualization (AMD-V) aka "SVM" was disabled by default. BIOS > MIT > Advanced Freq Settings > Advanced CPU Settings > SVM Mode Enabled & CoolNQuiet Enabled BIOS > MIT > XMP Profile 1 BIOS > BIOS > CSM Support Enabled & Fastboot Disabled & Full Logo Disabled You can also enable a PPT limit on the CPU lower than default. Lose a little bit of performance for a nice drop in heat. BIOS > Peripherals > AMD Overclocking > PBO to Enabled BIOS > Peripherals > AMD CBS > Package Power Limit > Manual & ## Picture shows a nice spot for power/performace around 50W ACPI ACPI needed for new motherboards. First versions were based on longhorn 5048 with some BSODs patched. There was a x86 version based on the original XP acpi with new instructions patched in assembly as well (6666). Latest version for XP/XP64 (7777) is here, https://www.mediafire.com/file/wsqgptapdrxhidf/ACPI2.0_v4_x86+x64_5.1+5.2.7z/file Drivers GPU Drivers (Tested nvidia GT710, GTX750Ti, and amd HD5450 video cards) NVIDIA 368.81 7/10/2016 AMD 14.4 09/05/2014 Onboard LAN/Audio drivers Realtek Audio 5.10.0.7514 8/23/2016 Realtek LAN 5.836.125.2018 1/25/2018 AMD CPU CoolNQuiet Driver 1.3.2.53 8/22/2007 Download AMD Processor Driver 1.3.2.53 and turn on power management if you want CPU to clock down during idle. Chipset Drivers (works with native storport on XP64, for XP you will need to integrate backported storport from Advanced) DEV7901/43C8 FCH/400 Series SATA Controller Option1: AMD 1.2.1.321 Download an old 13.4 XP/XP64 chipset pack from AMD. Open up amd_sata.inf and add in these lines underneath existing DEVs (a non B450 may have different DEV_): %AMDSATA.DeviceDesc% = amd_sata_inst, PCI\VEN_1022&DEV_7901&CC_0106 %AMDSATA.DeviceDesc% = amd_sata_inst, PCI\VEN_1022&DEV_7904&CC_0106 %AMDSATA.DeviceDesc% = amd_sata_inst, PCI\VEN_1022&DEV_43C8&CC_0106[/spoiler][spoiler=DEV7901/43C8 FCH/400 Series SATA Controller Option2: StorAhci_V1.0_20200928]Download Schtrom's StorAhci SATA AHCI Driver from sourceforge. Pros: Universal driver. Not limited to just AMD controllers. Cons: Sequential speed is slower compared to AMD 1.2.1.321 Needs SMART patch on backported win7 storport to enable SMART. DEV7901/43C8 FCH/400 Series SATA Controller Option2: StorAhci_V1.0_20200928 Download Schtrom's StorAhci SATA AHCI Driver from sourceforge. Pros: Universal driver. Not limited to just AMD controllers. Cons: Sequential speed is slower compared to AMD 1.2.1.321 Needs SMART patch on backported win7 storport to enable SMART. NVMe OFA NVMe 1.3 Storport Miniport Option1: 20180719 Download Schtrom's OFA NVMe 1.3 Storport Miniport from sourceforge. You will need to integrate a new version of storport.sys for it to work. Version 4173 (KB943545) or newer. You can also use the postSP2 update pack. Tested with a Samsung PM981 and storport 5.2.3790.4485. -Version 1.3 works. Version 1.5 stalled in the TXT setup just before format partition page. -Use MBR for boot drive. Native XP/XP64 does not boot from GPT. -Use NTFS. FAT32 starts install but hangs in the GUI setup halfway through Installing Devices. -No SMART data from CrystalDiskInfo, SMART with HWiNFO. DEV43D5 400 Series USB 3.1 XHCI Controller 1.0.5.3 Download the Windows 7 chipset pack for the B450 from AMD. 1.0.5.3 USB driver from USB31_PT for the controller and the hub works with the motherboard USB ports. But you get a Code 39 error. To fix, you will have to copy usbd.sys to your \system32\drivers folder for a live system. You can also modify the inf file in two spots to also copy over the usbd.sys file when it copies over the driver sys file like the amdxhc31.sys or amdhub31.sys. Use can decompress the usbd.sy_ file from your ISO or extract latest version from an unofficial service pack. In CMD, "expand usbd.sy_" Chipset Drivers (advanced) NTOSKRNL Emu_Extender required -Download NTOSKRNL Emu_Extender from sourceforge. https://github.com/MovAX0xDEAD/NTOSKRNL_Emu -Follow the instructions and compile backported drivers. THe USB driver needs Kernel Mode Driver Framework 1.11 (WDF 1.11). -Follow the instructions from above and create updated wdf files. Useful Tools: -Hexplorer or equivalent hex editor -Dependency Walker -PEChecksum.exe DEV7901/43C8 FCH/400 Series SATA Controller Option3: AMD 1.2.1.402 -Download the Windows 7 chipset pack for the B450 from AMD. -Open up amd_sata.inf and change the two lines that have NTAMD64.6.1 -> NTAMD64 (NTx86 if doing the 32bit version) -Add in these lines underneath existing DEVs if not already there (non B450 board may have different DEV_): %AMDSATA.DeviceDesc% = amd_sata_inst, PCI\VEN_1022&DEV_7901&CC_0106 %AMDSATA.DeviceDesc% = amd_sata_inst, PCI\VEN_1022&DEV_7904&CC_0106 %AMDSATA.DeviceDesc% = amd_sata_inst, PCI\VEN_1022&DEV_43C8&CC_0106 -Open up amd_xata.sys with hexplorer or equivalent, find and change ntoskrnl.exe -> ntoskrn8.sys. -Apply PEChecksum.exe on amd_xata.sys DEV149C Matisse USB 3.0 Host Controller usbxhci 6.2.9200.xxxxx Backported generic Win 8 USB3 driver from NTOSKRNL_Emu works. Needs WDF1.11 backport as well. NVMe Generic Windows 7 NVMe Option2: stornvme 6.1.7601.23403 Backporting Windows 7 NVMe drive works. No SMART info. NVME Samsung Option3: 3.3.0.2003 Backport the Samsung NVME driver. secnvme.sys and secnvme.sys imports need to be changed to NTOSKRN8.SYS like with the other drivers. No SMART with CrystalDiskInfo but it does work with HWiNFO. I only have a Samsung NVME so havent tested if the generic works with other brands. Chipset Drivers (null) DEV790B FCH SMBus Controller Null driver. Download an old 13.4 XP/XP64 chipset pack from AMD or get Windows 7 for the B450 chipset. Open up SMBUSamd.inf and add in these two lines underneath existing DEVs: %AMD.DeviceDesc0% = AMDSMBus, PCI\VEN_1022&DEV_790B %AMD.DeviceDesc0% = AMDSMBus64, PCI\VEN_1022&DEV_790B DEV1481 Starship/Matisse IOMMU Null driver. Download an old 13.4 XP/XP64 chipset pack from AMD or get Windows 7 for the B450 chipset. Open up AmdIOV.inf and add in this line underneath existing DEVs: %IOMMU.DeviceDesc%=NULL_DRIVER,PCI\VEN_1022&DEV_1481 DEV1486 Starship/Matisse Cryptographic Coprocessor PSPCPP Install null driver to remove from missing devices. DEV1485/148A Starship/Matisse Reserved SPP/PCIe Dummy Function According to the readme this should also be a null driver. Unlike the SMBus and IOMMU, this one has a sys file that tries to install. Update inf to add DEV1485 and DEV148A. ACPI\AMDI0030 Install null driver to remove from missing devices Extra Stuff VMware and USB flash drive passthrough When using VMware, if you connect a USB flash drive and try to pass it through to the guest OS, you will need to use a USB port that is using the generic backported USB driver in the host OS. It does not work then using the AMD USB31_PT 1.0.5.3 chipset drivers from the motherboard. From the article it looks like other motherboard specific drivers will have the same issue with a few exceptions. Once you get the Win8 USB3 up and running, you can replace the AMD motherboard USB drivers. https://kb.vmware.com/s/article/2041591 Tested with: XP64host with VM10.0.7(last XP version) and Win7x64host with VM10.0.7 & 15.5.6(last Win7 version). Testing passthrough with a Kingston USB2.0 flash drive works fine. But when connecting a Kingston USB3.0 flash drive vmware gets a "unable to connect to ideal host", and the drive does not load properly in the WinXP guest OS. VMware and USB3.0 flash drive If you change the USB compatibility in vmware in Settings from 2.0 to 3.0, then install the backported generic drivers to the XP guest OS, it will work properly. Note that the vm image hardware compatibility mode has to be 8 or higher, if you are using an image set to 6.5-7.x mode or lower then the USB 3.0 drop down menu will not show up. Edited June 22, 2022 by pappyN4 George King, luk3Z, SunLion and 2 others 3 2 Quote
pappyN4 Posted February 20, 2022 Posted February 20, 2022 (edited) Patches shell32 missing icon notification patch (x86/x64) patch shell32.dll by setting the timeout from 4000ms to 60000 ms and removing the SMTO_ABORTIFHUNG flag x86 6.0.2900.7551 @63CC9 A0 0F 00 00 6A 03 -> 60 EA 00 00 6A 01 x64 6.0.3790.6501 @29A50 A0 0F 00 00 C7 44 24 20 03 -> 60 EA 00 00 C7 44 24 20 01 where 0x0FA0 = 4000ms and 0xEA60 = 60000ms tcpip & tcpip6 max connection limit patch (x86/x64) x86 tcpip.sys 5.1.2600.7510 @4fbc6 0A 00 00 -> FF FF FF x86 tcpip6.sys 5.1.2600.7510 @33EB3 0A 00 00 -> FF FF FF x64 tcpip.sys 5.2.3790.6527 @c00cc 0A 00 00 -> FF FF FF x64 tcpip6.sys 5.2.3790.6527 @5e9a0 0A 00 00 -> FF FF FF where 0x0A = 10 and 0xFFFFFF = 16777215 maybe 0xFFFF = 65535 would have been enough? WinXPPAE v3.5 patch not needed, XP64 is good up to 128GB of ram. AVX/AVX2 patch (only x86 version exists) MovAX0xDEAD said: Let's make another dirty hack This time is AVX/AVX2 Enabler for Windows XP (x32 only) Again as Proof-of-Concept, only ntkrpamp.exe (MultiCPU+PAE) is done (still BETA v1), v5.1.2600.7581 (KB4463103 update, 2029056 bytes) Do it yourself (you need change kernel file on disk, remember about Microsoft's EULA): 1) xdelta3.exe -v -f -d -s ntkrpamp.exe ntkrpamp.delta ntkrpamp_avx.exe 2) put ntkrpamp_avx.exe as new ntkrnlpa.exe in /system32 folder, ntkrnlpa.exe will be selected by bootloader only if windows was installed as MultiCPU+PAE. Also you can force exact filename in boot.ini: add /kernel=ntkrnlpa.exe Links: ntkrpamp.delta v1 - ⇗ http://www.unibytes.com/facSy3u_83gLqw-Us4P3UgBB / ⇗ https://www.mediafire.com/file/a692j6ymc..._delta.zip/file ASM sources (FASM format) v1 - ⇗ https://pastebin.com/CbBFd5tM xdelta3.exe - ⇗ https://github.com/MovAX0xDEAD/KDNET/raw/master/xdelta3.exe P.S. Some test/diag utils fail with AVX detection due wrong coding, but proper projects like Prime95 do it right P.S. WinXP x64 kernel has different FPU context format, but i think it is possible to do same trick, but i'm not interested P.S.S Don't ask for AVX512, there is no free space in FPU context to store additional 16*AVX512_H(256bit) regs. WinXP x32 kernel allocates only 520 bytes(see _FXSAVE_FORMAT struct) for store all (2*ControlWords(128bit) + 8*FPU/MMX(128bit) + 8*SSE(128bit) + 8*AVX_H(128bit)) regs, this "520" harcoded to structs and code GPT native support on data volume. With XP32 you have to copy disk.sys and partmgr.sys from server2003x86, but with XP64 its based on 5.2 (like 2003x64). sndrec32 2GB patch (only needed for x86, x64 does not need patch) 5.1.2600.5671 @6C4B change 7E 2E -> 76 2E Patch for applications 4GB patcher to add /LARGEADDRESSAWARE flag for EXEs. Otherwise 32bit process is limited to 2GB. This would allow it to use all 4GB. Useful for some games or apps that can use a lot of RAM. https://ntcore.com/?page_id=371 Edited February 22, 2022 by pappyN4 adding George King, Dietmar and andrey2049 1 2 Quote
pappyN4 Posted February 22, 2022 Posted February 22, 2022 (edited) Build ISO with nLite WinXP64 ISO and updates en_win_xp_pro_x64_with_sp2_vl_x13-41611.iso 5eraph_Windows_XP_x64_Post-SP2_UpdatePack_ENU_v2019-08.7z; https://www.mediafire.com/folder/x6qqeye5y0a0x/x64 WinXP ISO and updates en_windows_xp_professional_with_service_pack_3_x86_cd_vl_x14-73974.iso XPSP3_QFE_UpdatePack_20210829_Pro.7z; https://www.4shared.com/web/directDownload/0t47E_Vhea/B8-gUmU2.8a5c8b6a84dcde59d76300e08ab95fac XPSP3_QFE_POSReady_Addon_20200528_5er.7z; https://www.4shared.com/web/directDownload/pCl2jGEqea/B8-gUmU2.7befe8c26d0ff79f226742fccad3d4c3 Note: order matters, in nlite have the UpdatePack run first, then the POSReady updates Note2: in POSReady updates, entries_POSUpdates.ini has a bug with nlite, you will need to comment out these lines ;Prevents Windows Setup copying drivers from driver.cab that the integrator failed to update ;drvindex.inf|ks.sys||2 ;drvindex.inf|termdd.sys||1 ;drvindex.inf|hsf_fs|hsf_fsks.sys|1 Compile NTOSKRNL_Emu; https://github.com/MovAX0xDEAD/NTOSKRNL_Emu Backport drivers/ create whatever patch files from above. Install nLite 1.4.9.3 extract Windows ISO to folder run nlite, customize as you want, make sure to import the update packs once you get to the create ISO stage stop ==============ACPI/NTOSKRNL/STORPORT/WIN8AHCI/WIN7NVME/WIN8USB3======================== open nlited ISO folder and extract SP3.cab (XP), SP2.cab (XP64) to a folder replace acpi.sys, add storport.sys, storpor8.sys, ntoskrn8.sys to folder use CabPack1.4 to recreate SP#.cab and replace cab file from ISO folder replace ACPI.SY_, add STORPORT.SY_, STORPOR8.SY_, NTOSKRN8.SY_ to I386 (XP), AMD64 (XP64) folder use cabsdk to compress eg: "CABARC -m LZX:21 N ACPI.SY_ ACPI.SYS" ------------------------------------------------ (I386 folder for XP) (AMD64 folder for XP64) in DOSNET.INF add (x64 already has a storport.sys line) Quote [FloppyFiles.1] d1,ntoskrn8.sys d1,storpor8.sys d1,storport.sys d1,storahci.sys d1,stornvme.sys [Files] d1,ntoskrn8.sys d1,storpor8.sys d1,storport.sys d1,storahci.inf d1,storahci.sys d1,stornvme.inf d1,stornvme.sys d1,wdf01011.inf d1,wdf01000.sys d1,wdfldr.sys d1,ksecd8.sys d1,ucx01000.sys d1,usb8.sys d1,usbhub3.inf d1,usbhub3.sys d1,usbxhci.inf d1,usbxhci.sys d1,wpprecor.sys [FloppyFiles.2] d1,ksecd8.sys d1,ucx01000.sys d1,usb8.sys d1,usbhub3.sys d1,usbxhci.sys d1,wpprecor.sys in TXTSETUP.SIF add (x64 already has a storport.sys line) Quote [SourceDisksFiles] storport.sys = 1,,,,,,3_,4,0,0,,1,4 usbd.sys = 1,,,,,,4_,4,0,0,,1,4 ;force load for mb that has xhci only wdf01011.inf = 1,,,,,,,20,0,0 [SourceDisksFiles.amd64] OR [SourceDisksFiles.x86] ntoskrn8.sys = 1,,,,,,3,4,0,0,,1,4 storpor8.sys = 1,,,,,,3,4,0,0,,1,4 storahci.inf = 1,,,,,,,20,0,0 storahci.sys = 1,,,,,,3_,4,0,0,,1,4 stornvme.inf = 1,,,,,,,20,0,0 stornvme.sys = 1,,,,,,3_,4,0,0,,1,4 wdf01000.sys = 100,,,,,,3_,4,0,0,,1,4 wdfldr.sys = 100,,,,,,3_,4,0,0,,1,4 ksecd8.sys = 1,,,,,,4_,4,0,0,,1,4 ucx01000.sys = 1,,,,,,4_,4,0,0,,1,4 usb8.sys = 1,,,,,,4_,4,0,0,,1,4 usbhub3.inf = 1,,,,,,,20,0,0 usbhub3.sys = 1,,,,,,4_,4,0,0,,1,4 usbxhci.inf = 1,,,,,,,20,0,0 usbxhci.sys = 1,,,,,,4_,4,0,0,,1,4 wpprecor.sys = 1,,,,,,4_,4,0,0,,1,4 [HardwareIdsDatabase] PCI\CC_010601 = "storahci" PCI\CC_010802 = "stornvme" USB\USB20_HUB = "usbhub3" USB\USB30_HUB = "usbhub3" USB\ROOT_HUB30 = "usbhub3" PCI\CC_0C0330 = "usbxhci" [SCSI.Load] storahci = storahci.sys,4 stornvme = stornvme.sys,4 usbxhci = usbxhci.sys,4 usbhub3 = usbhub3.sys,4 [SCSI] storahci = "Standard SATA AHCI Controller" stornvme = "Standard NVM Express Controller" usbhub3 = "USB 3.X Hub Driver" usbxhci = "USB 3.X Host Controller" [FileFlags] ntoskrn8.sys = 16 storpor8.sys = 16 storport.sys = 16 storahci.sys =16 stornvme.sys =16 wdf01000.sys =16 wdfldr.sys =16 wpprecor.sys =16 usbxhci.sys =16 usbhub3.sys =16 usb8.sys =16 ucx01000.sys =16 ksecd8.sys =16 [BootBusExtenders.Load] wdf01000 = wdf01000.sys [BusExtenders.Load] ucx01000 = ucx01000.sys [InputDevicesSupport.Load] usbxhci = usbxhci.sys usbhub3 = usbhub3.sys [InputDevicesSupport] usbhub3 = "USB 3.X Hub Driver",files.usbhub3,usbhub3 usbxhci = "USB 3.X Host Controller",files.usbxhci,usbxhci [files.usbxhci] hid.dll,2 hidclass.sys,4 hidparse.sys,4 usb8.sys,4 usbport.sys,4 usbxhci.sys,4 wdfldr.sys,4 [files.usbhub3] usbhub3.sys,4 usb8.sys,4 ksecd8.sys,4 wdfldr.sys,4 [files.ucx01000] ucx01000.sys,4 wpprecor.sys,4 wdfldr.sys,4 [files.wdf01000] wdf01000.sys,4 wdfldr.sys,4 [BootBusExtenders] wdf01000 = "Kernel-Mode Driver Framework 1.11",files.wdf01000,wdf01000 [BusExtenders] ucx01000 = "USB 3.0 Controller Extension",files.ucx01000,ucx01000 in HIVESYS.INF add Quote [AddReg] HKLM,"SYSTEM\CurrentControlSet\Services\storahci\Parameters\PnpInterface","5",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Services\storahci\Parameters","BusType",0x00010001,"b" HKLM,"SYSTEM\CurrentControlSet\Services\storahci\Parameters","IoTimeoutValue",0x00010001,"0x0000001e" HKLM,"SYSTEM\CurrentControlSet\Services\stornvme\Parameters\PnpInterface","5",0x00010003,"1" HKLM,"SYSTEM\CurrentControlSet\Services\stornvme\Parameters","BusType",0x00010001,"0x00000011" HKLM,"SYSTEM\CurrentControlSet\Services\stornvme\Parameters","IoTimeoutValue",0x00010001,"a" HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx\Setup","X1-WDF01011_INSTALL",0x00000000,"RunDll32.exe SetupAPI.dll,InstallHinfSection PostSetup 132 wdf01011.inf" HKLM,"SYSTEM\CurrentControlSet\Services\Wdf01000","Type",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Services\Wdf01000","Start",0x00010003,"0" HKLM,"SYSTEM\CurrentControlSet\Services\Wdf01000","ImagePath",0x00020000,"system32\drivers\wdf01000.sys" HKLM,"SYSTEM\CurrentControlSet\Services\Wdf01000","Group",0x00000000,"Boot Bus Extender" HKLM,"SYSTEM\CurrentControlSet\Services\Wdf01000","ErrorControl",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Services\USBXHCI","Type",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Services\USBXHCI","Start",0x00010003,"0" HKLM,"SYSTEM\CurrentControlSet\Services\USBXHCI","ImagePath",0x00020000,"system32\drivers\usbxhci.sys" HKLM,"SYSTEM\CurrentControlSet\Services\USBXHCI","Group",0x00000000,"Input Device Support" HKLM,"SYSTEM\CurrentControlSet\Services\USBXHCI","ErrorControl",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Services\USBHUB3","Type",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Services\USBHUB3","Start",0x00010003,"0" HKLM,"SYSTEM\CurrentControlSet\Services\USBHUB3","ImagePath",0x00020000,"system32\drivers\usbhub3.sys" HKLM,"SYSTEM\CurrentControlSet\Services\USBHUB3","Group",0x00000000,"Input Device Support" HKLM,"SYSTEM\CurrentControlSet\Services\USBHUB3","ErrorControl",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Services\Ucx01000","Type",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Services\Ucx01000","Start",0x00010003,"0" HKLM,"SYSTEM\CurrentControlSet\Services\Ucx01000","ImagePath",0x00020000,"system32\drivers\ucx01000.sys" HKLM,"SYSTEM\CurrentControlSet\Services\Ucx01000","Group",0x00000000,"System Bus Extender" HKLM,"SYSTEM\CurrentControlSet\Services\Ucx01000","ErrorControl",0x00010001,"1" HKLM,"SYSTEM\CurrentControlSet\Control\Wdf\Kmdf\Ucx\Versions\1\1","Service",0x00000000,"ucx01000" for SETUPREG.HIV use offlinereg-win32.exe by Erwan to add Quote offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Control\Wdf\Kmdf\1" setvalue "Version" "1.11" 1 offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Control\Wdf\Kmdf\KmdfLibrary\Versions\1" setvalue "Service" "Wdf01000" 1 offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Control\Wdf\Kmdf\Ucx\Versions\1\1" setvalue "Service" "ucx01000" 1 offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Control\Wdf\Schema\KmdfService" setvalue "Type" "0" 4 offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Control\Wdf\Schema\KmdfService\Object" setvalue "KeyPath" "CurrentControlSet\Services" 1 offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Control\Wdf\Schema\KmdfService\Object" setvalue "KeyRoot" "SYSTEM" 1 offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Services\Wdf01000\Parameters" setvalue "BuildNumber" "0" 4 offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Services\Wdf01000\Parameters" setvalue "MajorVersion" "1" 4 offlinereg-win32.exe SETUPREG.HIV "ControlSet001\Services\Wdf01000\Parameters" setvalue "MinorVersion" "11" 4 REPLACE Quote in storahci.inf [SourceDisksNames] 1 = %DiskId%,,,"\AMD64" OR 1 = %DiskId%,,,"\I386" in stornvme.inf [SourceDisksNames] 1 = %DiskId%,,,"\AMD64" OR 1 = %DiskId%,,,"\I386" in wdf01011.inf [SourceDisksNames] 1 = "Kernel-Mode Driver Framework 1.11",,,"\AMD64" OR 1 = "Kernel-Mode Driver Framework 1.11",,,"\I386" in usbxhci.inf [SourceDisksNames] 1="Generic USB xHCI Host Controller",,,"\AMD64" OR 1="Generic USB xHCI Host Controller",,,"\I386" in usbhub3.inf [SourceDisksNames] 1="Generic USB Hub Driver",,,"\AMD64" OR 1="Generic USB Hub Driver",,,"\I386" copy to AMD64 folder or I386 folder Quote storahci.inf storahci.sys stornvme.inf stornvme.sys wdf01011.inf wdf01000.sys wdfldr.sys ksecd8.sys ucx01000.sys usb8.sys usbhub3.inf usbhub3.sys usbxhci.inf usbxhci.sys wpprecor.sys ================================================================= =================Other Patches===================================== replace SHELL32.DL_ patched version to AMD64 or I386 folder replace TCPIP.DL_ and TCPIP6.DL_ patched version to AMD64 or I386 folder for x86 replace sndrec32,disk,partmgr, and other files from AVX/PAE patch to the I386 folder or the SP#.cab as needed etc... =================Make ISO====================================== make ISO in nLite and test. Edited February 14, 2023 by pappyN4 George King, andrey2049 and Dietmar 1 2 Quote
pappyN4 Posted February 22, 2022 Posted February 22, 2022 (edited) SATA driver speed tests (XP64 vs Win7x64) NVME driver speed tests (XP64 vs Win7x64) storport tests XPx86 storport 5.2.3790.4485 (from server 2003 x86) (default XP has no storport and drivers will not work) AMD 1.2.1.321 yes AMD 1.2.1.402+ntos8 no boothang StorAHCI schtrom yes NVME schtrom w2k3OFA1.3 no code10 NVME schtrom w2k3OFA1.5 no code10 NVME win7+ntos8 no code37 XPx86 storport 6.1.7601.23403 +ntos8 AMD 1.2.1.321 yes AMD 1.2.1.402+ntos8 yes StorAHCI schtrom yes NVME schtrom w2k3OFA1.3 no code10 NVME schtrom w2k3OFA1.5 no code10 NVME win7+ntos8 yes NVME Samsung+ntos8 no ================================ XPx64 storport 5.2.3790.4485 (default) AMD 1.2.1.321 yes AMD 1.2.1.402+ntos8 yes StorAHCI schtrom yes NVME schtrom w2k3OFA1.3 yes NVME schtrom w2k3OFA1.5 no boothang NVME win7+ntos8 no boothang XPx64 storport 6.1.7601.23403 +ntos8 AMD 1.2.1.321 yes AMD 1.2.1.402+ntos8 yes StorAHCI schtrom yes NVME schtrom w2k3OFA1.3 yes NVME schtrom w2k3OFA1.5 no boothang NVME win7+ntos8 yes NVME Samsung+ntos8 yes NVME OFA 1.3 no NVME OFA 1.3+nt8+sto8 no NVME OFA 1.5+nt8 no SMART tests Seagate HDD, Sandisk SSD, Samsung NVME CrystalDisk8.9.0a/HWiNFO640/GSmartControl0.90 XPx64 storport 6.1.7601.23403(msi patch/SMART patch) +ntos8 SATA AMD 1.2.1.321 Yes/Yes/Yes SATA StorAHCI schtrom 1.0_20200928 Yes/Yes**/Yes SATA storahci 6.2.9200.16384 Yes/Yes/Yes NVME schtrom w2k3 1.3 No/Yes/No NVME win7.23403+ntos8 No/No/No NVME Samsung+ntos EXEcrash*/Yes/No **StorAHCI schtrom 1.0_20200928 (when started HWi BSOD0x51(0x04,0x01,..., changed to other driver for test, no BSOD when changed back) XPx64 storport 6.1.7601.23403(msi patch) +ntos8 SATA AMD 1.2.1.321 Yes/Yes/Yes SATA StorAHCI schtrom 1.0_20200928 No/1stSATA/Yes SATA storahci 6.2.9200.16384 No/1stSATA/Yes NVME schtrom w2k3 OFA1.3 No/Yes/No NVME win7.23403+ntos8 No/No/No NVME Samsung+ntos EXEcrash*/Yes/No *EXEcrash Crystal8.3.0 last version to work with Samsung NVME driver on XP, newer ones crash) Win7x64 6.1.7601.23403 (default) AMD 1.2.1.402 Yes/Yes/Yes Win7msahci Yes/Yes/Yes NVME win7 No/No/No NVME Samsung Yes/Yes/No NVME OFA1.3 noboot NVME OFA1.5 noboot ACPI tests x64 Bad acpi 5048 - 2019.10.19 (Intel&AMD Final) - daniel_k Bad acpi 5048 - 2019.5.15 - skullteria Good acpi 5048 - 2019.9.1 (Ryzen) - diderius6 x86 G acpi 5048 - 2019.10.11 - diderius6 G acpi 5048 - 2019.10.19 (Intel&AMD Final) - daniel_k G acpi 5048 - 2019.11.1 - diderius6 Bad acpi 5048 - 2019.5.15 - skullteria G acpi 5048 - 2019.6.25 - infuscomus G acpi 5048 - 2019.6.30 (Ryzen) - diderius6 G acpi 5048 - 2019.8.25 - daniel_k G acpi 5048 - 2019.8.27 (Intel&AMD Final) - daniel_k G acpi 5048 - 2020.10.24 - daniel_k, diderius6 Bad acpi 6666 - 2019.10.18 - OuterSpace, diderius6 Bad acpi 6666 - 2019.10.20#1 - OuterSpace, diderius6 G acpi 6666 - 2019.10.20#2 (Intel&Ryzen) - OuterSpace, diderius6 untest acpi 6666 - 2020.10.22 - daniel_k G acpi 6666 - 2020.10.22 - OuterSpace, daniel_k G acpi 6666 - 2020.10.23 - diderius6 G acpi 6666 - 2020.12.28 - diderius6 G acpi 6666 - 2021.2.1#1 - daniel_k (2013none, 2015both amdi0030, amdif0030) G acpi 6666 - 2021.2.1#2 - daniel_k (2013none, 2015both amdi0030, amdif0030) G acpi 6666 - 2021.8.28 - daniel_k, diderius6 Edited February 22, 2022 by pappyN4 formating andrey2049 1 Quote
pappyN4 Posted February 22, 2022 Posted February 22, 2022 (edited) Ok, now for something new. Sadly doesnt seem to be much interest for x64 ACPIs. I started using it back in 2005, so I broke away from 16bit applications long time ago. I didnt actually use XP, I went from 2000 to XP64. Anyways... I'll start by saying I have no idea about patching ACPIs. I have no idea what each specific patch was made for. I dont know how to debug errors from ACPI. In the words of Mov AX, 0xDEAD, blindly turning off checks is not always the best idea. All I've done was compare the latest x86 5048 acpi (which worked on my ryzen), and tried to match existing patches and missing patches based on any calls or values by patterns and general structure/flow in IDA Free on the x64 5048. Some I feel confident I found the right one, others are reasonable, and one that is a total guess as it had nothing guess from. Feel free to open IDA and see for yourself. 5048 x86 "2020.10.24 - daniel_k, diderius6", all patches below are based on compare to original unpatched / patched file =Matched in x64 @27a80 00 00 00 -> A8 97 03 @27c58 28 92 03 -> 00 00 00 =Matched in x64 @d443 75 -> EB =MaybeMatch in x64 @15f15 8B F7 -> 89 FF -ex1 to x64 @283d6 7D -> EB -ex2 to x64 @d2b0 74 -> EB -exClose1 to x64 @f7e1 74 -> EB -exClose2 to x64 @4511 0F 84 39 01 00 00 -> E9 3A 01 00 00 90 -experiNotSure1 to x64 @317ac 75 -> EB @317c5 21 -> 00 5048 x64 "2019.6.30 (Ryzen) - diderius6" =Matched from x86 @4ae40 00 00 00 -> B8 C8 05 @4b1f0 18 BF 05 -> 00 00 00 =Matched from x86 @18ca4 0A -> 00 =MaybeMatch from x86 @26337 08 00 14 C0 -> 00 00 00 00 @26429 74 -> EB --end of origial 2019.06.30 patch ----------------------EXPERIMENT---------everything below this is untested guess from x86 -experi1 test @51bf1 79 -> EB -experi2 test @198dc 0F 84 7F -> E9 80 00 -experiClose1 test @1c666 74 -> EB -experiClose2 test @9638 0F 84 A8 01 00 00 -> E9 A9 01 00 00 90 -experiNotSure1 test @5fa63 74 -> EB test @5fa94 78 -> 00 experi1 in subroutine that has \\_S1,2,3,4,5 in the beginning shorty before the end, block just after a ZwPowerInformation and 2 ExFreePoolWithTag, x86 stop jump to 2001, 0A5, call: extern KeBugCheckEx:Dword so we do same, stop jump to __stdcall __noreturn extern KeBugCheckEx:qword =========== experi2 in function shortly after x64@18ca4,x86@d443 with 58080206h,4449485Fh push/mov, PNP0C0F is jumped so that it doesnt get to a 5349445Fh, which then goes to 10006h,0A5h ds:keBugCheckEx x64 version has a lot more paths to 0A5h, but same one jump to get away, good idea? I dont know. Another learning experience. This one I used the same E9 jump as from expericlose2, but this time I just tried with my own guess for the offset. I ended up with a bit longer jump then I wanted so I guess my math wasnt exactly correct, but was able to get it there eventually. =========== experiClose1 similar structure, compares 0FFFFFFFFh has 2 KeBugCheckEx, and ends with ExFreePoolWithTag first KeBugCheckEx is left alone, goes straight from head to bugcheck, other one near end is the one that is jumped out =========== experiClose2 similar structure, 4449555Fh,0Dh,0A5h to KeBugCheckEx at end, mentions 800h vs 80000000000h and 0A000h vs 0A00000000000h between x86 and x64 on x86 jumped to "retn" block, This one was a learning experience. Using the same E9 3A 01 landed in the wrong spot. Makes sense after looking up E9 (JMP) is based on offset distance entered. On the x64 where you want to go wasnt in the same spot. So used IDA free in text mode to see where the text jump landed with the wrong value from x86, in hex calculated the difference on how much further was needed, then added it to the JMP. So 31 01 (aka in hex calculator 0131 + 6F = 01A9), so A9 01. =========== experiNotSure1 not much to guess with, short subroutine, 2 KeBugCheckEx to avoid, total guess on this one Update https://www.mediafire.com/file/ietiycbz6eueacz/xp64_acpi5048_2022.04.12.rar/file Edited April 18, 2022 by pappyN4 andrey2049 and George King 1 1 Quote
pappyN4 Posted February 26, 2022 Posted February 26, 2022 IdaFree70 has fake limitation. If you change ida64.exe Major/minor Operating System version from 6.0 to 5.2 it works fine. No missing dependencies in DependencyWalker. x64 bit process. andrey2049 and George King 1 1 Quote
George King Posted April 6, 2022 Author Posted April 6, 2022 @pappyN4Do you have prepatched ACPI.sys based on your latest findings? Quote
pappyN4 Posted April 11, 2022 Posted April 11, 2022 (edited) Samsung NVMe and SMART with CrystalDiskInfo The samsung nvme driver is able to display SMART data in XP/Win7. To get CrystalDiskInfo to work instead of crashing when you start it in XP/XP64 you will have stop it from using WMI. Open DiskInfo32 or DiskInfo64 with a hex editor, find where "\ \ . \ r o o t \ c i m v 2" is and change it to something like "\ \ . \ r o o t \ n o w m i". Tested on version 8.15.2 630069006D00760032 -> 6E006F0077006D0069 Samsung NVMe potential issues When I installed the latest nvidia 368.81 driver it caused the Samsung 3.3.0.2003 to stop working on XP64. @Andalu tested the same drivers on an Intel B250/GT730 and worked fine. After playing around with it, installing nvidia 355.98 appears to work/coexist with the Samsung NVMe driver on XP64. I've only tested on a GT710 so far but hopefully same result for my GTX750. Something to keep in mind if you have a amd/B450/gigabyte combo. On XP32 the Samsung driver did not work (code10), using the default non patched, or with the PAE patch /4GB. It did however work when PAE patched using /128GB or /all. Both with 355.98 and 368.81 Trim tests O&O Defrag 17.5 is the best from all the ones I tested. Works on SATA and NVMe SSDs. AMD/Samsung/nativeWin7 drivers were all able to TRIM. Can be run from CMD line so you can schedule it if you want. NVMe Trim ADataSSDToolbox doesnt see (Win7/samsung/SchtromOFA13 driver) TxBENCH see but no trim (Win7/samsung/SchtromOFA13 driver) SSDTool 0.95 see but trim didnt work (../../samsung) Naraeon5.4.0 win7 no see, SchtromOFA13 trim didnt work, samsung TRIM WORKS O&O Defrag 17.5 win7 TRIM WORKS, SchtromOFA13 see but no trim, samsung TRIM WORKS SSD Trim Naraeon5.4.0 AMD yes, Win7msahci yes, SchromAHCI no see, Win8ahci no see O&O Defrag 17.5 AMD yes, Win7msahci yes, SchromAHCI no trim, Win8ahci no trim used trimcheck0.7 to see if it worked (https://github.com/CyberShadow/trimcheck) *trimcheck x64 works also if Major/Minor changed from 6,0 *Naraeon has a "not a valid date and time error", doesnt affect functionality *O&O can be run from CMD line, needed to change Major/Minor from 6,0 down to 5,2 (or 5,1) to install Nvidia GPU driver & custom resolution Based on a few posts i found, Nvidia 355.98 is that last version where you can add custom resolution if for example you have a ultrawide screen or 4k monitor that you want to use. It looks like XP is limited to displayport HBR1 (8.64 Gbit/s). There is a bit of other stuff as well but roughly, horizontal pixels × vertical pixels × (3 × bits per color channel) × refresh rate in Hertz = Bits per second. Calculator https://tomverbeure.github.io/video_timings_calculator Ex: 2560 × 1600 × (3 × × 75 = 5898240000 bits/s / 1024³ = 6.86 Gbit/s 3840 x 2160 x (3 x x 40 = 7962624000 bits/s / 1024³ = 7.41 Gbit/s https://www.vogons.org/viewtopic.php?f=63&t=72471 http://wp.xin.at/archives/5616 Edited April 24, 2022 by pappyN4 George King and andrey2049 1 1 Quote
pappyN4 Posted April 11, 2022 Posted April 11, 2022 On 4/6/2022 at 2:10 PM, George King said: @pappyN4Do you have prepatched ACPI.sys based on your latest findings? @George King If you want to test I can send it to you. I have not tested myself. Quote
George King Posted April 11, 2022 Author Posted April 11, 2022 23 minutes ago, pappyN4 said: @George King If you want to test I can send it to you. I have not tested myself. Yes, please PM me those new patched files. I will try them on my machines. Quote
pappyN4 Posted April 15, 2022 Posted April 15, 2022 USB Attached SCSI (UASP) When using the AMD USB drivers for the motherboard with a UASP capable device it defaults to using the default USB Mass Storage Device (usbstor), same as a standard USB stick. With the backported Win8 drivers it's different. If you do not have a UASP driver installed (USB\Class_08&SubClass_06&Prot_62) then it will not find a driver by default. You can force install by manually selecting Universal Serial Bus Controllers - USB Mass Storage Device, or install a uasp driver. Note that some motherboards may have a deadlock issue when using the uasp driver during reboots with the USB adapter still connected. If you select Safe Remove, reboot works fine, otherwise it doesn't finish the reboot. You will need to use a deadlock patched version of the driver if thats the case. The following test is with a JMicron USB to PCIE adapter, VID152D PID0583 and a XG5 256GB NVMe. The Gen2 port on the B450 chipset and the Gen1 port on the B450 and on the Ryzen2. Drivers are the default XP usbstor 5.2.3790.5829, VIA uasp 6.1.7600.4002, and win8 uaspstor 6.2.9200.16384. George King and andrey2049 1 1 Quote
pappyN4 Posted April 22, 2022 Posted April 22, 2022 "Installed INF does not contain digital signature" warning I got this warning after integrating the USB3 drivers. You will need to patch syssetup.dll file to get rid of it. Original patch is from @ Mattiwatti. I updated the x64 patch to match the one found in the 2019 updates. x86 syssetup.dll 5.1.2600.5512 @33bfe 8B F8 3B FE 75 20 -> 31 C0 31 FF 90 90 @33da6 8B F0 85 F6 75 17 -> 31 C0 31 F6 90 90 @35535 0F 84 9F 00 00 00 -> E9 A0 00 00 00 90 @37f03 3B C6 -> 31 C0 @37f0b 75 3E -> 90 90 x64 syssetup.dll 5.2.3790.4226 @423dc 75 4C 0F B6 0D 8C A2 08 00 -> 90 90 31 C9 90 90 90 90 90 @42431 75 4C 0F B6 0D 36 A2 08 00 -> 90 90 31 C9 90 90 90 90 90 @424cb 0F 85 D5 00 00 00 -> E9 D6 00 00 00 90 @425a6 40 8A 74 24 30 -> 31 F6 90 90 90 @3fe50 85 DB 0F 84 E3 00 00 00 -> 31 DB E9 E4 00 00 00 90 @41d2b 85 C0 8B F8 75 25 -> 31 C0 8B F8 90 90 @41fb6 85 C0 8B D8 75 1C -> 31 C0 8B D8 90 90 @4204b 0F 84 84 03 00 00 -> E9 85 03 00 00 90 @46bf9 85 C0 8B D8 75 47 -> 31 C0 8B D8 90 90 @571ab 0F 85 DB 00 00 00 -> E9 DC 00 00 00 90 @5728c 40 8A 74 24 40 -> 31 F6 90 90 90 @7204b 85 C0 75 1F -> 31 C0 90 90 @78a22 75 61 0F B6 0D 46 3C 05 00 -> E9 B9 00 00 00 90 90 90 90 George King and andrey2049 1 1 Quote
K4sum1 Posted November 12, 2022 Posted November 12, 2022 @George KingDo you have a slightly older version or a newer version of the generic USB 3 drivers for XP x86 and x64? Quote
George King Posted November 13, 2022 Author Posted November 13, 2022 15 hours ago, K4sum1 said: @George KingDo you have a slightly older version or a newer version of the generic USB 3 drivers for XP x86 and x64? Here is my latest ported drivers collection for XP2ESD. These drivers are signed with my custom certificate. To get them signed import certificate into system before installation. All drivers are compatatible with XP and 2003 in both architectures. No other touch neede, every driver is standalone Whats included? x64 AMD_RAID_6.1.5.00025 AMD_SATA_1.2.001.0337 AMD_SATA_1.2.001.0402 AMD_SD+MMC_1.0.0.0106 AMD_USB3_1.1.0.0145 Generic_AHCI_1.0 Generic_AHCI_6.2.9200.20652 Generic_MSAHCI_6.1.7601.25735 Generic_NVMe_1.3.1014.00 Generic_NVMe_1.5.1200.00 Generic_NVMe_10.4.49.0 Generic_NVMe_6.1.7601.23403 Generic_SD+MMC_6.2.8056.0 Generic_Touchpad_6.2.9200.16384 Generic_UASP_6.1.7600.4002 Generic_UASP_6.2.9200.16384 Generic_USB2_5.2.3790.5203 Generic_USB3x_6.2.9200.21180 Generic_USBMassStorage_5.2.3790.5829 IRST_16.8.3.1003 IRST_18.36.3.1019 RSTe_4.7.0.1119 Samsung_NVMe_3.3.0.2003 TPM_6.1.7600.16385 WinUSB_6.2.9200.16384 x86 AMD_RAID_6.1.5.00025 AMD_SATA_1.2.001.0337 AMD_SATA_1.2.001.0402 AMD_SD+MMC_1.0.0.0106 AMD_USB3_1.1.0.0145 Generic_AHCI_1.0 Generic_AHCI_6.2.9200.20652 Generic_Disk_5.2.3790.4171 Generic_MSAHCI_6.1.7601.25735 Generic_NVMe_1.3.1014.00 Generic_NVMe_1.5.1200.00 Generic_NVMe_10.4.49.0 Generic_NVMe_6.1.7601.23403 Generic_SD+MMC_6.2.8056.0 Generic_Touchpad_6.2.9200.16384 Generic_UASP_6.1.7600.4002 Generic_UASP_6.2.9200.16384 Generic_USB2_5.2.3790.5203 Generic_USB3x_6.2.9200.21180 Generic_USBMassStorage_5.2.3790.5829 IRST_16.8.2.1002 RSTe_4.7.0.1119 Samsung_NVMe_3.3.0.2003 TPM_6.1.7600.16385 WinUSB_6.2.9200.16384 Download https://www.mediafire.com/file/dap6k6n96t27l1a/DP_Ported_DriversCollection_v24.7z/file Certificate, just run it from CMD reg add "HKLM\SOFTWARE\Microsoft\SystemCertificates\Root\Certificates\2516FF09B7786B05CBB7B96B97690821A13B36AF" /v "Blob" /t REG_BINARY /d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f reg add "HKLM\SOFTWARE\Microsoft\SystemCertificates\TrustedPublisher\Certificates\B9B6F07ACD8C0A29597BB2AC1EECF59D046697A7" /v "Blob" /t REG_BINARY /d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f andrey2049 and luk3Z 1 1 Quote
UsefulAGKHelper Posted December 26, 2022 Posted December 26, 2022 Just so you know I made a topic about trying to boot XP from UEFI Class 3 on modern hardware: https://forums.mydigitallife.net/threads/unresolved-getting-windows-xp-to-boot-on-uefi-class-3-from-modern-computers-without-bsods.86331/ Quote
Flamel Posted June 18, 2023 Posted June 18, 2023 (edited) On 4/11/2022 at 6:18 PM, George King said: Yes, please PM me those new patched files. I will try them on my machines. Hi George, do you still have this ACPI 5048 by @pappyN4? Just like as you used to last year, I'm running into trouble to get my secondary GPU (940MX) working under Windows XP. You said that installing this ACPI solved your issue, and then, when ACPI 7777 v4 got released a couple of days later, you also managed to solve it too, as you stated here and here. Could you please upload ACPI 5048 by @pappyN4 and ACPI 7777 v4 if you still has these files? ACPI 7777 v5 and Dietmar's new one did not work for me and 6666 solved my battery detection issue, but still does not detect my secondary GPU. I tryed to install XP without ACPI, but my 940MX would still not initiate after NVIDIA driver installation, giving me error code 10. Edited June 18, 2023 by Flamel Quote
K4sum1 Posted June 18, 2023 Posted June 18, 2023 I doubt you will get a secondary GPU working ACPI or not, but here you go. https://files.catbox.moe/w8mm0d.7z Flamel 1 Quote
Flamel Posted June 18, 2023 Posted June 18, 2023 1 hour ago, K4sum1 said: I doubt you will get a secondary GPU working ACPI or not, but here you go. https://files.catbox.moe/w8mm0d.7z Thank you! I will test them all! Quote
Flamel Posted June 19, 2023 Posted June 19, 2023 (edited) 9 hours ago, K4sum1 said: I doubt you will get a secondary GPU working ACPI or not, but here you go. https://files.catbox.moe/w8mm0d.7z Unfortunately, none of them worked on my notebook. I did not even managed to get Windows XP installed with those ACPI files Every installation ended up in BSOD before OOBE. Edited June 19, 2023 by Flamel Quote
K4sum1 Posted June 19, 2023 Posted June 19, 2023 Well, if the other ACPIs you used worked, that means your GPU uses Optimus, which Vista and earlier can't use. Causes the code 10. Flamel 1 Quote
Flamel Posted June 23, 2023 Posted June 23, 2023 On 6/19/2023 at 1:24 AM, K4sum1 said: Well, if the other ACPIs you used worked, that means your GPU uses Optimus, which Vista and earlier can't use. Causes the code 10. Hey man, sorry for bothering you again, but I thought to myself: What if I disable the iGPU (and Switchable Graphics too) from BIOS and use my dGPU as main display for the notebook? Would not Windows XP forced to recognize only my dGPU and let it initialize after install NVIDIA drivers? It could do the trick, right? Like, look at the attached image, where it says "Switchable Graphics should only be enabled for Windows 7 and later versions" Quote
K4sum1 Posted June 23, 2023 Posted June 23, 2023 Depends on your laptop, if you have the option, go for it. But if it's a Dell it should've automatically disabled it when in XP, because that's what my M4800 did. Flamel 1 Quote
Flamel Posted June 23, 2023 Posted June 23, 2023 Just now, K4sum1 said: Depends on your laptop, if you have the option, go for it. But if it's a Dell it should've automatically disabled it when in XP, because that's what my M4800 did. It's a HP Zbook 15 G3 I am planning to order, because it does has an option to disable iGPU, and the Quadro M1000M or M2000M that comes with it, is compatible with 368.81 driver perfectly. Precision 7510 is less expensive (circa R$ 1.000,00 less) though, but its Quadro M1000M has device ID 06D9.1028, while DELL'S driver only supports 06E5.1028 SectionID025. I do not know if it worths the risk, since driver installation could be completly ruined by that damn SectionID... I have checked 372.70 (from Vista driver) and the SectionID between 06D9.1028 and 06E5.1028 differs by 2. I do not know if replacing "06E5.1028" to "06D9.1028" and "SectionID025" to "SectionID023" (or leaving as default) would do the trick... But anyway, thank you for your reply! Quote
K4sum1 Posted June 23, 2023 Posted June 23, 2023 I have a M4800 upgraded with the M2200, it appeared to work under XP but I didn't get around to testing any 3D applications. I would suggest getting something Ivy Bridge, 8570W/8770W or M4700/M6700 for better XP/Vista compatibility Flamel 1 Quote
