I am still new to this and not to sure I understand. Where will I drag and drop it. Inside the "XPCD" there are only 2 files in the "System32" folder. Is this something that has to be done after installation?
Ok here goes.....
#1 reshacker the sysdm.cpl to your desired effect.
#2 download the attached prog and run it.
#3 right click on sysdm.cpl and send to the cabtool.
#4 replace the sysdm.cp_ with the one you have modified and prepared into your i386 folder,
