Posted December 17, 20213 yr Using WinSetupfromUSB I select "Auto Detect and use F6 SATA/RAID/SCSI Driver" and get "No Driver Found", however the installer itself does in fact make it past the usual point of BSOD 000007b, I then get to a screen that has the "ENTER" to start the XP installation but then the laptop shuts off. The HDD LED blinks a for a little bit but thats all. The Drive is a 1TB Toshiba which is freshly formatted using diskpart to NTFS single partition. The laptop specs are 16GB DDR3 RAM (2x8GB) Intel 6200u NVidia GTX940M 2xUSB3.1 Gen1 1xUSB2.0 Edited December 17, 20213 yr by AaronS
December 27, 20213 yr On 12/17/2021 at 8:56 PM, AaronS said: Using WinSetupfromUSB I select "Auto Detect and use F6 SATA/RAID/SCSI Driver" and get "No Driver Found", however the installer itself does in fact make it past the usual point of BSOD 000007b, I then get to a screen that has the "ENTER" to start the XP installation but then the laptop shuts off. The HDD LED blinks a for a little bit but thats all. The Drive is a 1TB Toshiba which is freshly formatted using diskpart to NTFS single partition. The laptop specs are 16GB DDR3 RAM (2x8GB) Intel 6200u NVidia GTX940M 2xUSB3.1 Gen1 1xUSB2.0 Try XP2ESD
