If you want to open command window while browsing Vista Windows Explorer to avoid "cd" commands in it do the following..
Right-click on any folder in Vista Explorer while holding down the shift key. A context menu will open with two new options:
"Open Command Window Here" and
"Copy as Path"
Other option will copy current path to clipboard..
